psy472
They are sending a new one to me. Apparently they have a satellite repair shop inside the US that I sent my damaged unit to.Hopefully you get it back fixed soon.
It depends. You are correct though that DAC matters. Bifrost is hamstringing your MJ3. At least get the Yggy GS2. Preamping is to fill in weaker sounds. EQ won’t give you stronger bodied sounds. The MJ3 doesn’t like preamping much though. You lose the Mj3 resolution.what exactly are you looking for? i know you mentioned the width not being what you expected. Personally, i believe in DAC's going straight into amps. Preamps are played out and excessive to me...i go for the sound i want within the dac and amp, thats all. I may fool around with EQ here and there but i right now to my BF2/64 going straight into my MJ3 sounds about 90% for me. Which is why I plan on stepping up my dac.
Not looking for now.. that was only a question of whether it would not be a bigger change to upgrade DAC vs. preamping the Mentor. I'm good for now, slowly adapting to the width as well. Anyway, still burning in .what exactly are you looking for? i know you mentioned the width not being what you expected. Personally, i believe in DAC's going straight into amps. Preamps are played out and excessive to me...i go for the sound i want within the dac and amp, thats all. I may fool around with EQ here and there but i right now to my BF2/64 going straight into my MJ3 sounds about 90% for me. Which is why I plan on stepping up my dac.
Definitely agree about the BF2, i can literally hear that its maxed out in capability compared to the MJ3. I can hear that the MJ3 is capable of more. Its starting to drive me crazy actually lolIt depends. You are correct though that DAC matters. Bifrost is hamstringing your MJ3. At least get the Yggy GS2. Preamping is to fill in weaker sounds. EQ won’t give you stronger bodied sounds.
I may not have gotten the MJ3 if I got the Yggy first. The change was that drastic. The improvement from JoT2 to MJ3 was like 10% only.Definitely agree about the BF2, i can literally hear that it’s maxed out in capability compared to the MJ3. I can hear that the MJ3 is capable of more. Its starting to drive me crazy actually lol
You can tell your wife, is either this new music box or prostitutes and drugs, you decide.Technically possible, but is such preamping considered business as usual, especially for such good amps like mentor is? I'd rather upgrade the DAC if anything. Seems to me that should bring a bigger difference... which I actually might do at some point.
The great thing about Denafrips DACs is that they all look the same. So if one day there will be Terminator instead of Pontus, my wife will walk around without ever noticing any change. On the other hand, another box like Lyr+ would be a conversation starter .
by all accounts its a beast at it's price point.I may not have gotten the MJ3 if I got the Yggy first. The change was that drastic. The improvement from JoT2 to MJ3 was like 10% only.
For those wanting tube preamp, you can probably do it with the new Vali Schiit just released. It’s also a single tube preamp like the Lyr. I don’t have experience with it so YMMV.
I bet Freya into Mentor would sound fabulous.For folks who want some tube magic with their Mentor or MJ3, I suggest getting a dedicated tube preamp. Skip using another amp to preamp to another amp. That's not ideal, as the signal has to go thru more parts and more chances of muddying the path.
Advantages of using a dedicated tube preamp (instead of another amp) is one less amp in the signal, and you have more XLR and RCA inputs on preamp (ie like Freya N) so you can connect multiple dacs or other sources on the preamp to switch sources as you please, and keeping one XLR connection out to the Mentor or MJ3, very convenient You also have more preamp outputs too.
Then there's the benefit of tube rolling to fine tune that sound of your choice. Just don't skimp on using dirt cheap cables, if adding a preamp in the chain.
Or just keep it simple with dac and amp and forget about the fuss and enjoy.
Yea but what if she wants a share of the prostitutes and drugs?You can tell your wife, is either this new music box or prostitutes and drugs, you decide.
then she's a keeper for the short term but a red flag long termYea but what if she wants a share of the prostitutes and drugs?
Triple the fun.Yea but what if she wants a share of the prostitutes and drugs?
heh, and I assumed music equals sex, drugs (and rock 'n roll). nevermind, maybe next time.You can tell your wife, is either this new music box or prostitutes and drugs, you decide.
