mbgrace
Member of the Trade: Grace Design
- Nov 5, 2004
Hi,
I'm not sure if I understand your question. The m902 does have balanced inputs (no balanced outputs). They are female connectors which are wired with pin 2 hot, pin 3 cold and pin 1 ground. Is this what you wanted know?
Michael
Originally Posted by GoRedwings19 Hi michael does the balanced inputs of the grace 902 use the inverse signal of the XLR connection??? I was just wondering because I have a balanced cable and wanted to utilise it. |
Hi,
Michael
