Standalone Grace SDAC coming again (in production)...plus something else to keep an eye out for next week. (Where is that ninja emoji??)
Grace Design x Massdrop m9XX DAC/Amp Review: First Impressions
- Thread starter jude
21qz
- Mar 10, 2011
Hi all, I've been using my Grace m9xx for a couple years now and love it!
i pair mine with the AKG K702 65th anniversary edition and it sounds fantastic.
i also use Tidal for Master tracks. Am i the only one here with this combo?
My volume stays between 70-80.
I purchased my m900 last month (from Thomann, not Massdrop) and I really enjoy it. Can someone recommend a travel case for it? I'd like to take it on my work travels... not as a portable, as a when the day is done and relaxing at the hotel.
GraceDesign
Member of the Trade: Grace Design
- Jul 13, 2012
The Pelican 1060 Micro case works well.
Thanks for the quick suggestion. I guess with the 1062 Pelican foam insert.
Also, thanks for making this unit. I absolutely love it. It sounds so good with the Audeze LCD-MX4...
I just bought FiiO x7 1St gen and willing to connect FiiO x7 via USB with M9xx but I couldn't hear anything. I tested x7 with DAC function with computer, it's ok . And The M9xx works ok with my computer.
I got OTG cable with one head is host. Which head should I plug in M9xx? Any can help me to connect M9XX with FiiO X7 as transport only. Thanks
477621
- Jun 6, 2017
I use the same setup for my evening listening but while working have the M9XX in front of my Slee ULDE.
I agree it drives the Anni very well. Which Anni have you got, flat pad or angled? Mine are the flat ones. 600 ish serial.
21qz
- Mar 10, 2011
edit: my preferred volume range in more like 75-90, 85 being the sweet spot!
Serial 778. Its hard to find any portable set up as good as this combo, and i have a few.
21qz
- Mar 10, 2011
dumb question alert, how do i activate the 5v,2a. What would/can i plug into that?
Why would we use this. Ive only been using the usb 2.0 to PC.
21qz
- Mar 10, 2011
Also anyone here compare this to an iFi iDSD Black Lable?
477621
- Jun 6, 2017
You listen a bit louder than I do, but yes, I agree otherwise that it is a great little box. It even drives my thirsty K340's convincingly.edit: my preferred volume range in more like 75-90, 85 being the sweet spot!
477621
- Jun 6, 2017
That explains why you are listening so much louder than I am. That plug puts it in High Power mode. Goes from sounding good to sounding great. Much more headroom.dumb question alert, how do i activate the 5v,2a. What would/can i plug into that?
21qz
- Mar 10, 2011
do i just plug another usb cord in 5v,2a, what do i plug into ?
eeagle
The original MD m9XX delivery included a Monoprice wall charger and USB cable for the power input. Any low noise 2.0A USB power source/charger will work.do i just plug another usb cord in 5v,2a, what do i plug into ?
You will also want to be sure you have the latest drivers for the m9XX for higher bit rate decoding.
21qz
- Mar 10, 2011
I’m good on the drivers!
I’ll have to dig up that box. Thx
Total: 8 (members: 0, guests: 8)
