Hifiman HE1000-SE
Aug 25, 2018 at 5:29 AM Post #33 of 5,245
I for one did have build-quality issues with my unit. The leather headband was way too short and thus had too much tension, causing an uncomfortable concentration of the pressure on the middle of my head. Two esthetically questionable foam cushions passably helped. Later successively both sides of the leather band separated from the frame. I couldn't fix it any other way than with super glue. Another problem of the headband was that the stops didn't really provide reliable stops; each time I took the headphone off and put it on again I had to readjust the headband. After maybe 1½ years the right socket began to develop interrupts and finally died. So I brought it to my dealer for repair or replacement. I got a brand new pair. With which everything is fine now, except for the headband stops, which could be called nonexistent. My solution was to hammer some short pieces of wire into the stop holes of my preferred postition. I was glad when the V2 pads were finally available – they provided a definitive improvement both sonically and in terms of comfort. A few weeks after purchase the polyester skin of one of them began to separate from the foam filling. After all I got a new pair for free. So far no problem anymore.
Of course my sympathy for HiFiMan has greatly suffered, not least after the temporary V2 pads boycott. On the other hand I'm not strictly against improvements of existing models and don't feel duped by the SE. I will certainly audition it and compare it with the Susvara (of which I had a brief audition already – to my ears the DAVE can drive it effortlessly, with better sound than via EF1000). Well, the sound quality of HiFiMan's top models is simply too high to be ignored.
Aug 25, 2018 at 11:26 AM Post #34 of 5,245
So JaZZ, since you have long experience with the HEKs, I be grateful for your impression of how they compare to the Susvara sonically.
I'm a big fan of my HEKv2, so I'm curious. I've had the HEKv1 (and later the HEKv2) since the HEK was introduced.
Thanks in advance.
Aug 27, 2018 at 10:34 PM Post #35 of 5,245
I agree with everything you said, but are you sure that the polyester pads are more comfortable than the velour pads? I'm not talking about the shape, but strictly the material.
Aug 28, 2018 at 8:12 AM Post #36 of 5,245
That may be an individual thing. Yes, for me the new pads are way more comfortable. The old ones felt hot and kind of scratchy after five or ten minutes.
Sep 8, 2018 at 10:06 PM Post #40 of 5,245
I own both the HE1000v2 and the Susvara and I think that the Susvara is much better from a sound quality perspective. When I first purchased the Susvara I thought that the improvement in sound quality was not necessarily worth the extra $3,000, but after 1 year I am increasingly delighted that I purchased the Susvara and I no longer listen to my HE1000v2 (which I should probably sell).
Jeff.
Sep 9, 2018 at 12:00 AM Post #41 of 5,245
Jeff.
Yeah when you get to this end of the spectrum, even what one might call a 10% improvement could be considered massive and worth a lot of extra money. An example I can give right now is comparing the Kimber Kable Hero to the Hero AG interconnect in my current system. I'd call the Hero AG 10-15% better yet it costs many times more, but I may very well purchase a Hero AG.
Sep 21, 2018 at 11:24 PM Post #43 of 5,245
Bright and unrealistic sound ? really confusing review.
Sep 21, 2018 at 11:26 PM Post #44 of 5,245
After reading the below
http://majorhifi.com/hifiman-he6se-review/
I realised "Major-Hifi" is to be disregarded on a whole. Seems like a website dedicated to making money (even worse than the usual suspects,) rather than well done reviews and high quality content.
