Hutnicks
- Jun 16, 2012
So something just happened now that makes me question all this spending on HQ iems, so I was going through some old stuff in my drawer and came across these from my old sony ericsson phone.
http://www.amazon.com/Sony-Ericsson-Original-Headset-Walkman/dp/B0027V4AR4/ref=sr_1_4?ie=UTF8&qid=1406126133&sr=8-4&keywords=sony+ericsson+headset&dpPl=1
I figured, let me test them out with all this HQ music and compare to my XBA30, back then I didnt know about music as I did now, so I plugged them in expecting to be disgusted; to my amazement....they sound great! I thought to myself ok its probably jsut the mind adjusting, I went to my xba30 expecting to be blown away, sure it has cleaner bass, bigger sound stage and little details but overall its not what IMO you would expect for a $200 iem compared to a measly $10 pair.
These sound very good, everything is super clear, the mids and highs are good, the lows are not as clear per say but they are there at least, aside from a slight low end leakage they are balanced as well.
Now obviously the 30's are better no doubt but are they $200 worthy? Recently I bought the xb90ex and those retailed for like $60, to my amazement too aside from the obvious low end and sub bass emphasis they are clear and the mids and highs are just as good as the 30, so I wonder are these $200, $300, $400+ iem's really worth it? Something like the re400 is another example of price/value.
I mean being 100% honest, if I was stuck with these headphones I would not be complaining at all, the only headphones I cant stand are earbuds, those things suck lol
Well you picked a phenomenally good pair of OEM'd earphones to compare with. I actually posted them in the MH1 thread ages ago as a non ergonomic disaster alternative to the MH1.
Whats the saying. "Even a blind squirrel finds a nut every once in a while."? There are times when I believe that should be Sony's motto
Now if you happened to get the mono earbud with that set and can find another and some cable and foam booties...........................................
