Holo Audio Cyan 2 DAC
May 8, 2024 at 1:36 PM Post #826 of 882
May 8, 2024 at 1:54 PM Post #827 of 882
so in most important ways, its is not a 'ladder' as in PCM ladder. It is like the DSC2 I have sitting here with its resistor 'ladder' of equal weighting fed by shift register. An FIR filter to put it simply.
Where I am trying to understand the Cyan is the 8 by 8 architecture.
I am assuming they are applying their proprietary tech that linearizes the R2R in some way to the DSD filter.
So the Cyan would seem to be fundamentally an 8 element system?
May 8, 2024 at 2:06 PM Post #828 of 882
Current Spring 3 and May are using linear compansation solution, which is not present in Cyan 2.
For example Spring 3 description states: "New linear compensation tech achieves 0.00005% equivalent accuracy by eliminating resistance and PCB-induced errors."
It looks so.
May 8, 2024 at 2:30 PM Post #829 of 882
It looks so.
Okay I get it.
Holo audio has two 'ladders' for each format.. PCM has two and DSD two. Redundancy.
They call the DSD converter a ladder DAC, but that's more just marketing, and yes, while DSD FIR filters can use an array of resistor elements, (or caps) it isn't the same and IMO leads to consumer confusion.
So for linearity they have a DSP that 'compares' the two 'ladders' in some kind of unique element matching. That is an extremely elementary understanding of what is going on, so of course I am compelled to learn more how his version of 'element matching' really works.
So based on the link you send me, the Cyan2 is indeed an 8 tap/resistor DSD Filter. The Spring is a 16 tap.
P.S.
On that thread.. gosh it gives me a headache at all the confusion about how DSD works. My anxiety is through the roof just reading a few posts! It really isn't that hard to understand how the conversion works, and I am a liberal arts degree professional pianist and I can get it! People overcomplicate it WAY to much. The other problem, and I have witnessed this frustration first hand, and see it all over that thread, is how some of these manufacturers (smsl, topping come to mind) muck it up to where things don't work exactly right, the analog outputs are often inadequate and lead to audible issues with the poor handling of ultrasonic noise, the manuals are pathetic, and it just contributes to the mass of confusion. The last SMSL I tested with AK4191+AK4499EX in what I will call 'normal' mode, no DSD DIRECT or BYPASS, gave two filter choices for DSD (wide and narrow) but they were the exact same filter! No difference. On DSD64 they both rolled off at 19khz and stopband was reached quickly at 30khz. On both Narrow and Wide! There was no wide filter in practice. And I could go on.
May 9, 2024 at 6:38 AM Post #832 of 882
Hi guys, my first post in this thread.
I'm considering replacing my TT2 (which I really like, but got bored with after 3+ years) with something else. I had Spring3 KTE for some time year or two ago and liked it, but now I need something with a smaller footprint. Cyan2 seems to have a very good opinions here. I have a couple of questions (maybe I'll find some answers in this thread later, but it's not so easy to read 56 pages :wink: )
  • do you have any comparisons to TT2 used as a DAC?
  • is there really an audible difference between Cyan2 and Spring3?
  • most important: TT2 cannot be used with both RCA & XLR plugged in at the same time. It is soo annoying, since I have two amps (Feliks Euforia EVO & Violectric V550). I know that Cyan2 has no output switch. Can you use it with two outputs connected at the same time, with two amps powered on?
  • While I test other headphones from time to time, I'm generally a ZMF fan, so it's a majority of my HP collection. Any opinions on this pairing? (ideally also with Violectric and Euforia :) )
May 9, 2024 at 7:10 AM Post #833 of 882
Yes I'm using it with SS (XLR) and OTL tube amp (SE) at the same time no issue. But ground loops tend to be very system dependent.
Yes I owned TT2 some time ago (as well as Dave Mscaler and so on....). Without upsampling Cyan2 sounds different, more in line what you would expect from nos R2R designs.
With HQPlayer you can get it to sound kinda similar to Chord designs (using Sinc-M and its variations filters). Or you can go another path with upsampling to DSD
May 9, 2024 at 7:13 PM Post #834 of 882
Hey all,
So I've had a little bit more of a chance to take in the Cyan 2 over the past few days and think I can offer a little more of my impressions overall. Personally, I'm a big fan of comparisons specifically because just describing subjective sound, while useful to some degree, often makes it hard unless there's a sense of "scale" to something else I'm familiar with. In this case, I desperately wish I had a Spring/May or even another R2R dac to compare to. Unfortunately, I don't, and I think it means my impressions will be fairly useless for most of you. But in the effort of at least providing some early takes, I had the chance to compare it directly to my RME ADI-2 this morning.
First off, based on the pictures, I expected this thing to be sorta small. Even only a bit bigger than my RME. I was wrong. It's obviously not the size of a Spring or May, but thing is no slouch. You can kind of tell from my pictures above that its a fairly decent size. And, man, is it BEEFY. I mean, it's a brick. And interestingly, that's kind of how I'm hearing the sound as well. Beefy.
Before I get to comparisons, here's what I noticed straight-up as I listened to a lot of familiar music the past few days: First off, separation is fantastic. Just, no matter what I listen to everything just feels so easy to pinpoint and, in some cases, extremely so. It can be super holographic at times. But interestingly, I also noticed that the soundstage feels less wide than I'm used to. It *can* be wide, depending on the recording, but a lot of stuff that I'm used to being wide seemed slightly pulled forward. It was a bit jarring at first, making some tracks feel more in your face with the vocals, but I quickly realized this is actually something I like. As I've adjusted to it I've realized the stage is deeper than I'm used to. There was a day there where I worried that it might even become fatiguing, but today, when I put my RME back in the chain and listened, I immediately missed it because I realize it's quite fun! The C2 kind of places the music right dead in front of you, and it makes everything a bit more engaging. I'm making this point because I can see this being an issue for some. And again, this is subjective, and I have to account for how the C2 is interacting with the other components in my system, so it may be different for others, but I noticed this effect with both my speakers (Focal Chora 826s) and my headphones (Hifiman Arya Stealths).
So on the comparison side: on my RME I made sure to turn off any EQ presets to just get everything as even as I could. It's one thing that's just been a huge difference with the C2. You just plug it in and that's it. It does the rest. There is nothing you can do with it. No input switching, no nothing. You just play music through it and it shows you the input and the sampling rate. That's been an adjustment for sure, but with the RME I just constantly fiddle and then get frustrated thinking about how I may not be hitting my ceiling there. The fiddling almost becomes a distraction more than an advantage. And no matter how much fiddling I do, I could never seem to get something I was 100% satisfied with. This is one reason I decided to upgrade my DAC. I wanted something I *couldn't* fiddle with. Boy did I get that.
So ya, the first thing I noticed, as I mentioned above, was weight and texture. Every piece of music I put on feels thick and textured. Putting my RME back in, I noticed, even if I turn up the bass there, it's not working my Rel sub to the degree that the the Cyan 2 is. I mean, to put it simply its a difference between the RME being intentionally polite and neutral and the C2 being bold and energetic. And when I say energetic, I really mean it. The attack is potent. I mean, guitars, drums, everything just punches. Now on the RME, to get this kind of punch I had to really push the high and low frequencies a bit more, and it often would quickly get fatiguing. On the C2, however, you get a kind of natural, organic punch but the resolution is still there in spades. It doesn't feel like you're losing precision or resolution in any way. But I'd be lying if I said that, from my initial impression, this isn't a DAC that has a pretty big personality. I'd be doing you a disservice to suggest that this is a very clean and neutral DAC that is going to present everything uncolored. Granted, I'm not as astute as a lot of you, but that just hasn't been my experience so far. But for me, it's EXACTLY what I was looking for. I absolutely LOVE listening to vinyl records for this very reason and I have wanted an R2R dac, and specifically a Holo Audio DAC, because I knew that this is the kind of experience you can get there.
One caveat here is that Focal speakers are kind of known for being punchy like that as well, so I know that the C2 is working in concert with them to really deliver that experience in spades. If you have a more laid-back speaker the experience may be different. I just know that when I went back and forth between the RME and the C2, there was a palpable difference in energy. The RME has maybe just a TINY bit more resolution behind it, but it seems like it may be at the expense of immersion. The C2 has a ton of resolution, though, and I'd say it's only a fraction off. It's just that the C2 has more texture to everything. The timbre of guitars feels more realistic and organic, whereas the RME presents everything sparkling clean and a bit sanitary.
I'm not sure what more to say here, and happy to answer questions anyone has, but I will just close by saying this: it took me all of a couple songs listening to the RME before I was desperate to get the Cyan 2 back in the chain. The cleanliness is nice to have in some respects, but with the Cyan 2, so far it's been a blast to just throw ALL kinds of things at it and see how it presents it. I've been rather shocked and surprised on numerous tracks where I got a presentation that felt altogether new and exciting and it's that experience I think we hope to have when we introduce new components to the chain. And I am extremely grateful for Holo Audio working to build this unit. I've wanted to try a Holo Audio DAC for a long time, but I just don't make that kind of money. I'm so grateful they managed to transplant some of the magic I've read about for so long into a package like this that I could afford and try out. I have not been disappointed in the least. And I very much look forward to hearing from those that have other R2R dacs and even the Spring or May to see how this stacks up!
Which one has a better tighter bass punch and slam?
May 10, 2024 at 11:30 AM Post #835 of 882
Wildism came through on the perfect day when I'm trying not to think about the Aegis release and sent my shipping notification :smiley:
May 12, 2024 at 10:44 PM Post #836 of 882
.....My Red came Friday, now I'm just waiting on the arrival of the Cyan2, and I have a question - it seems that the consensus about preferred input is USB, but before I sell off my fancy i2s cable I just wanted to make sure. The Red is being used as a streamer/Roon bridge, not a DDC, so it seems to me that USB being asynchronous and well regarded is the way to go? Thanks in advance.
May 14, 2024 at 10:21 AM Post #837 of 882
Hey. I received my Cyan 2 today. So far so good. After installing the W11 driver, the exclusive mode and the dynamic sample rates are working (both were not working without the driver). But I have short sound interruptions with few tracks. I think only tracks with a sample rate greater than 48kHz seems to be the problem.
I use Tidal (exclusive mode). Connection is USB from W11 PC to the DAC.
May 14, 2024 at 10:34 AM Post #838 of 882
I'm expecting mine later today and will be running USB from Win11 Tidal exclusive as well. I'll see if I run into the same issue.
May 14, 2024 at 10:37 AM Post #839 of 882
Ready now!
Is this the small version, the HS300? I thought the Cyan 2 will just fit with the HS400. I want to order a DDhifi rack as well, but currently I am considering the HS400, but it is not known when it will be back in stock and it really hard to find alternatives - and here the smaller HS300 comes into play :)
May 14, 2024 at 12:18 PM Post #840 of 882
Anyone moved from the Cyan 2 to the spring 3 L2? Is it worth?
