- Mar 20, 2013
iFi audio Pro iDSD Signature
The Pro iDSD Signature is our new flagship reference class DAC and then some! The Signature edition builds on the strengths of the original, multi-award winning Pro iDSD.
It continues to cater for those who love good music delivered at the highest quality.
Use the Pro iDSD Signature as a standalone unit, a DAC/preamp, a network streamer and a headphone amplifier.
The Pro iDSD Signature has:
The powerful XMOS XU216 X-Core 200 series chipset processes incoming digital data and enables the Pro iDSD Signature to provide state of the art audio support – from MP3, 32-bit/768kHz PCM, DSD512, 2xDXD and full MQA decoding.
Thanks to the Crysopeia FPGA Digital Engine the Pro iDSD Signature brings studio grade DSD remastering to a wider audience. It can upconvert PCM and DSD files to DSD512 and DSD1024. And all controlled from an app in the palm of your hand.
Listen to the your music to in solid-state, tube or tube+ modes, your choice, all at the flick of a switch.
Our Crysopeia FPGA Digital Engine strikes again as it enables the Pro iDSD Signature to offer several options when it comes to digital filtering. The GTO filter adds gravitas and a new dimension, and while the Bit Perfect, Bit Perfect+, Apodising and Transient Aligned filters give you even more choices to tweak the sound.
The discrete, fully balanced Class A amplifier stage offers adjustable gain.
Coupled with the re-crafted power supply board which offers up to 100x lower noise, the music is buttery smooth.
Within and without – we left no stone unturned in our quest for the cleanest, purest, power for the Pro iDSD Signature (same for Pro iCAN Signature too!)
iFi audio Pro iCAN Signature
The Pro iCAN Signature is our new upgraded edition of the original Pro iCAN.
The Signature edition builds on the strengths of the Pro iCAN and features even more ultra-grade audiophile components designed to take your listening to a higher plane than ever before.
It is a top-of-the-line headphone amplifier that is capable of driving anything and everything from the most sensitive custom iEMs to the AKG K-1000, the most difficult to drive headphone ever made.
It is also exceptionally powerful and will drive any headphone on the planet. It boasts balanced output power of >14,000mW and single-ended power output of >4,800mW.
And with variable gain, you can adjust the Pro iCAN Signature to drive your headphone of choice.
With the Pro iCAN Signature you can enjoy the sound of solid-state or tubes in one single package.
For some of your recordings, and depending on whether you are listening through headphones or speakers, you may prefer the ‘lively’ feel of solid-state or for others, the more ‘luxurious’ feel of Tube or Tube+. The choice is yours at the flick of a switch in real time.
XBass is our analogue ‘bass boost’ that enhances the low frequencies without muddying the mid-range. 3D Holographic for Headphones undoes the negative sonic impact of listening to recordings that were originally created for loudspeakers.
3D Holographic for Loudspeaker Systems corrects the spatial distortion and restores the natural soundstage.
Headphone connections include the new 4.4mm balanced Pentaconn output as well as a fully balanced XLR, a single-ended 6.3mm and our unique S-Balanced 3.5mm output.
Our S-Balanced output cuts distortion by 50% with single-ended headphones connections.
Within and without – we left no stone unturned in our quest for the cleanest, purest, power for the Pro iCAN Signature (same for Pro iDSD Signature too!)
A Signature step up
The Signature takes the original Pro iDSD and pushes it even further towards perfection.The Pro iDSD Signature has:
- a sonically darker background and a punchier bass
- upgraded power -supply components to lower the overall system noise by 300%
- precisely matched NOS GE5670s tubes
- added support for USB1.0 (PS4/PS5)
- a new aluminium remote control
- a top-of the range iPower Elite power supply included
Stacked. With tech.
The Pro iDSD Signature uses a quad-stack DAC – 4 x DACs in an interleaved configuration – to deliver exceptional resolution.The powerful XMOS XU216 X-Core 200 series chipset processes incoming digital data and enables the Pro iDSD Signature to provide state of the art audio support – from MP3, 32-bit/768kHz PCM, DSD512, 2xDXD and full MQA decoding.
E-tailoring
The Pro iDSD Signature, like its predecessor, takes sonic tailoring to the extreme.Listen to the your music to in solid-state, tube or tube+ modes, your choice, all at the flick of a switch.
Your choice. The only choice.
- Stream wirelessly from Tidal, Spotify, Napster, QQ Music and more
- Use Airplay to enjoy playback from your iPhone, iPad or Mac
- Go wired via an Ethernet connection to play from a router or NAS (Network Attached Storage)
- Use DLNA network audio playback with smartphones, tablets, Windows/Linux computers
- Connect to a hard disc drive (HDD)
- Pop in a USB memory stick or SDHC card
Power cleans. Absolute.
The Pro iDSD Signature, ships with our flagship iPower Elite.Coupled with the re-crafted power supply board which offers up to 100x lower noise, the music is buttery smooth.
Amp it up to ultra
Enhancements to the Pro iCAN Signature include:- Revised circuit design incorporates even more ultra-grade audiophile components
- Upgraded power supply circuits to eradicate even more noise and distortion
- Top of the range iPower Elite offboard AC/DC power supply included
- Hand-selected and matched tubes in the output stage
- 4.4mm Pentaconn balanced-headphone output
- New aluminium remote control
Beautifully balanced Pro power
The Pro iCAN Signature sports an end-to-end fully differential balanced circuit design that delivers ultra low distortion. This means extraordinary quality with minimal interference and reduced crosstalk. The sound is cleaner, deeper and more dynamic.It is also exceptionally powerful and will drive any headphone on the planet. It boasts balanced output power of >14,000mW and single-ended power output of >4,800mW.
To tube or not to tube…?
Or to Tube+? That is the question.With the Pro iCAN Signature you can enjoy the sound of solid-state or tubes in one single package.
Signature by name…
The Pro iCAN Signature wouldn’t be ours without our signature sonic tweaks. Just like the original, it boasts XBass and 3D Holographic settings so that you can calibrate sound to suite your system and personal taste.XBass is our analogue ‘bass boost’ that enhances the low frequencies without muddying the mid-range. 3D Holographic for Headphones undoes the negative sonic impact of listening to recordings that were originally created for loudspeakers.
Get connected
The Pro iCAN Signature boasts a plethora of fully balanced and single-ended connections.Headphone connections include the new 4.4mm balanced Pentaconn output as well as a fully balanced XLR, a single-ended 6.3mm and our unique S-Balanced 3.5mm output.
Power is everything.
The Pro iCAN Signature, ships with our flagship iPower Elite.Coupled with the re-crafted power supply board which offers up to 100x lower noise, the music is buttery smooth.
Stay updated on iFi audio at their sponsor profile on Head-Fi.
