gotcha, thanks.I'm not a member of the forum police. That said, when one agrees with a post, the normal response is to "like" that post.
iFi audio's SilentPower Collection: GND Defender, DC Blocker, Nova, and SupaNova!
- Thread starter iFi audio
Its all good your covering most areas noise comes from, but one are ifi have missed is noise from the network. I think most people stream there music these days. Noise from wired ethernet enters your streamer. And my understanding is wired Ethernet always sounds better then wifi if you put alittle effort of audio hygien on it.
For exempel i replaced my tp link ax 50 router and netgear gs108 switch original psu with ifi i power x and the sound improved alot, smoother , cleaner better details in bass, mids, highs. And better picture and sound with Apple tv 4k. I think thers room for more improvement though.
Todeon
- May 26, 2011
Any Measurements available?
Amir likes to measure stuff over at AMR. Not a fan of the conclusions he draws, but the measurements seem accurate.Any Measurements available?
asifur
nice stuff!The sound of SilentPower
iFi’s new SilentPower range tackles mains-related noise to improve audio/AV system performance.
Alongside its award-winning collection of audio devices for home and portable use, including class-leading DACs and headphone amps, iFi makes a range of accessories to tackle common issues that affect the performance of audio systems. The prime objective is to reduce noise in the audio signal which may be engendered in various ways, from problems caused by USB interfaces to issues with mains electricity.
iFi’s latest collection of specialized ‘audio enhancers’ deals specifically with mains-related noise. The all-new SilentPower range consists of four products at launch: the DC Blocker, the GND Defender and a pair of IEC power cables called Nova and SupaNova.
Introducing the DC Blocker and GND Defender
These two little devices look similar – they both measure 68x37x32mm – but they are designed to tackle different problems that can result in an audible hum. They connect to the power inlet at the rear of any audio component, with the user’s power cable attaching at the other end. They can be used individually or together, depending on the issue(s) the user is attempting to solve.
DC Blocker – eradicating ‘DC on the mains’
The DC Blocker is a neat, highly effective solution to ‘DC on the mains’ – a problem well known to affect the performance of audio equipment and a significant cause of irritating transformer hum. In theory, the mains electricity we obtain from the sockets in our homes should be pure AC, with a perfectly symmetrical sine wave alternating between positive and negative phases. In reality, for reasons that are many and varied, this AC voltage is ‘polluted’ with DC voltage to varying degrees, causing ‘DC offset’.
The AC transformers typically found in home audio equipment cannot tolerate the presence of significant DC in the mains supply without being compromised. Transformers may become ‘saturated’, which can cause an annoying mechanical hum. This may most obviously affect hi-fi amplifiers containing toroidal transformers and may also impinge upon an amp’s power delivery.
The DC Blocker is capable of canceling more than 1000mV of DC voltage, thereby correcting the DC offset and rebalancing the AC sinewave. It does this ‘intelligently’ – in other words, it adjusts its performance according to the level of DC detected. This solves the problem of transformer hum caused by DC on mains and helps to optimize the sonic performance of any audio component to which a DC Blocker is connected.
GND Defender – fighting against ground-loop hum
If you can hear a hum or buzz through your speakers, it is likely that you have a ground loop problem. This occurs when two or more audio components in a system are connected to a common ground (or earth) point via different paths – for example, if two different wall sockets on the same circuit are used to power different components in a single audio/AV system in which the components are connected via electrical (as opposed to optical) signal cables.
If a problematic ground loop exists, the GND Defender resolves the issue by disconnecting the loop running through the connected component. By using one or several GND Defenders in a hi-fi system, the user can ensure that all components are connected to a common ground via a single path, eradicating the resulting hum through the speakers
Interference caused by ground loops can also affect picture quality in AV systems, resulting in issues such as visible scrolling bands. The GND Defender will help to solve this problem, too.
Both the DC Blocker and GND Defender are constructed so that they do not compromise the RFI/EMI shielding or filtering that may be offered by the connected power cable or filtering device further upstream. They are solidly made, their casing has a high dielectric rating and they surpass the highest safety standards. And, with a voltage rating of 90V to 240V, they can be used all over the world.
Nova – the affordable high-performance mains cable
iFi has made a number of clean-power products in its nine-year history to date, but these did not include an IEC mains cable for home audio components – until now! The Nova is a specialized power cable with a high-end construction that belies its affordable price point, delivering a serious upgrade over standard mains leads that imbues sound with greater clarity, space, and definition.
The Nova incorporates five conductors, each made from heavy-gauge, continuous-cast OFHC (Oxygen-Free High Thermal Conductivity) copper. Two pairs of live and neutral conductors have arranged on either side of the grounding (or earth) conductor, which is positioned at the center of the cable. This geometrically balanced configuration causes the magnetic fields generated by the live and neutral conductors to cancel each other out perfectly, ensuring the grounding conductor is unaffected by residual magnetism and unwanted induced voltage – iFi calls this design Ground Zero.
A further pair of air-dielectric delineators – polymer matrix tubes filled with air – are arranged on either side of the earth conductor, keeping the two pairs of live and neutral conductors apart whilst improving the cable’s overall dielectric performance and constructive solidity.
Each individual live and neutral conductor sports multiple layers of insulation and shielding. First, a dielectric made from a polymer matrix is extruded over the OFHC copper conductor. Surrounding this is an oxygen-free copper shield. And covering the shield is a further layer of polymer insulation. These individually shielded conductors, plus the air-dielectric delineators, are twisted in a circular helix around the central, untwisted grounding conductor, itself wrapped in polymer insulation – this twisted arrangement further aids RFI/EMI rejection. The cable is completed with a tough yet flexible polymer outer sheath and iFi’s audiophile-grade connectors, with oxygen-free copper conducting pins coated in tarnish-resistant 24ct gold.
The result of this sophisticated mix of materials and construction is a power cable offering constant impedance and superior rejection of EMI/RFI, maintaining the purity of mains electricity feeding each component in an audio or AV system. While the effect of this cable on sound quality is significant when used on its own, it combines brilliantly with iFi’s PowerStation mains-conditioning bar – the PowerStation filters out common mode and differential mode noise from the mains supply, while the Nova maintains optimum purity right through to the connected component.
SupaNova – advanced mains cable with active noise filtering
The SupaNova active power cable takes the Nova and adds a cylindrical housing part way down its length. This cylinder contains Active Noise Cancellation II – the latest version of iFi’s proprietary noise-busting tech – in combination with advance-filtering components.
Most power-conditioning products engage passive noise reduction through a selection of filters and regulators. While this can be effective, it has inherent disadvantages compared to iFi’s active system, which uses inverse noise current to cancel out the noise in the mains signal. The way this works is comparable to the technology in noise-cancelling headphones.
Noise in the mains supply occurs at different frequencies, depending on the cause. Passive noise reduction systems are effective at the top end of the frequency spectrum but often less so at lower frequencies. In addition, passive systems need large capacitors to be truly effective, which make the best such products bulky and expensive. iFi’s Active Noise Cancellation II technology enables a power-conditioning device that is highly effective at reducing noise consistently across the entire frequency spectrum yet sufficiently compact and lightweight to position within the mains cable itself.
By combining the Nova’s sophisticated construction with Active Noise Cancellation II, iFi has delivered a do-it-all clean-power cable solution that delivers optimised power to individual audio/AV system components without the need for a separate mains conditioning device. Sonic improvements delivered by the SupaNova power cable include greater clarity and definition, plus enhanced dynamic and spatial qualities, avoiding the apparent softening of leading edges, timing and dynamics that can occur with lesser mains filtering products.
Price and availability
All four devices in the iFi SIlentPower range launch this month – the DC Blocker and GND Defender are on sale now, and the Nova and SupaNova are available from April. RRPs as follows:
• DC Blocker: £129, €149, US$129 • Nova: £169, €199, US$169 (1.8m cable)
• GND Defender: £99, €129, US$99 • SupaNova: £349, €399, US$349 (1.8m cable)
Really hope you guys can take trade-in, I have some old iFi stuff
erics75
I worry the ground defender plus dc blocker with a heavy power cable is going to apply too much leverage to the power socket of my equipment and possibly physically damage it. It's like putting a lever in the socket and pulling down.... Maybe my fears are unfounded, but man my gut reaction to that setup was no way that can be good for the power socket.
omegaorgun
Previously known as FireLion
Try Audioholics he will test cables for vendors.Amir likes to measure stuff over at AMR. Not a fan of the conclusions he draws, but the measurements seem accurate.
ra990
Agree, you'll probably want to put something underneath it to support the weight and prevent it from pulling down on the socket.I worry the ground defender plus dc blocker with a heavy power cable is going to apply too much leverage to the power socket of my equipment and possibly physically damage it. It's like putting a lever in the socket and pulling down.... Maybe my fears are unfounded, but man my gut reaction to that setup was no way that can be good for the power socket.
omegaorgun
Can we see some measurements vs standard power cables?The sound of SilentPower
- Mar 20, 2013
Will there be a Zen Blue V2 anytime soon?
It's too early to discuss that
We haven't, our iPower PSUs lower it so connect one to your switch and/or router and enjoy the change
Out of curiosity, what sort of measurements would you like to see?
Stay updated on iFi audio at their sponsor profile on Head-Fi.
There is probebly more noise that happens in the router/switch that leaves router/switch and travels in ethernet cable that can be filtered out. You allready had powerstation so you dident need power cables then?We haven't, our iPower PSUs lower it so connect one to your switch and/or router and enjoy the change
It allready exist a product like this that won award but its always good with options.
- Mar 20, 2013
There's place and time for everything, some products can't be rushed
On a more serious note, we wanted to make a power bar first and move from there.
snk8699
Is it recommended to use the new iFi power cables in conjunction with the PowerStation as they are all employing the Active Noise Cancellation 2 technology? I assume the PowerStation would benefit from using two SupaNova power cables (one from the wall to the PowerStation and one from the PowerStation to a device) instead of the stock power cable that comes with the PowerStation? I am aware I'm asking the manufacturer's advice in regards to their product line-up, but I'm curious if these power products were designed as part of the same ecosystem.
ThanatosVI
Hey iFi audio maybe you know the answer to my question from page 1, or can ask those Who developed itIt's too early to discuss that
What gauge thickness does the supanova have? (Either in awg or mm2)
