RIGATIO
Never heard the M7 sorry. But the Max is good.Hi. And comparing M7 to Kann Max? Im really interested.
Thanks. I have M7 and I saw Kann Max recently. And Im thinking if buy it.Never heard the M7 sorry. But the Max is good.
I would stay with the M7 personally, Shanlings are smoother on top.Thanks. I have M7 and I saw Kann Max recently. And Im thinking if buy it.
Not for our app, but you can install alternative apps if you need support for .wvHello. Question to Shanling, will support for the .wv format be added?
Have any question about our players? Just PM me or send me email.
Stay updated on Shanling at their sponsor profile on Head-Fi.
Thank you for answer.Not for our app, but you can install alternative apps if you need support for .wv
Stay updated on MusicTeck at their sponsor profile on Head-Fi.
now you stay with outdated used sp1000 that bought for 1000€ and new fiio m15s returned back to store...., im bought M7 insteed of m15s or dx240,I would stay with the M7 personally, Shanlings are smoother on top.
Hi guys,
does anybody know if Line-out output is implemented on both jacks (3,5mm & 4,4mm), or only on one of them?
I did some searching, but couldn't find anything about it.
what filters best for extend more highs?
does EQ settings works on M7 with bluetooth connected TWS? or only wired iems?Settings affect both outputs.
Linear phase fast-roll off.
