Can I get away with this method of heatsinking for the grlvs? I plan on running 8ohm speaker loads. I admittedly have only tested with 50-600ohm headphone loads, but the small sinks I had on the grlv's barely got warm at all. Maybe 105*F max. I have 100VA 30v transformers. I seem to recall someone mentioning that 100VA and the low overhead 30vac secondaries mean less regulator heat from the grlvs? Below is what I was thinking of doing. I could also rotate them 90* left, bolting the L bracket to the side plate but that's even thinner steel than the bottom plate, and would move the DC outputs closer to the 90vac input on the grhv to it's right. I could also rotate the grlv 180* and remote mount the regs to the ~1.5mm aluminum back plate, but that would bring the grlv 30vac inputs closer to the DC jacks as well.
Second, here's what I can get away with for IEC - grhv proximity. Think it will be a problem?
It would give me enough room for the (admittedly too "deep" but fantastic looking and heavy duty power switch at the top, plus room for distribution blocks for mains/grounds.
Big thanks to anyone willing to share their wisdom.
