sbcontt
- Apr 8, 2013
There are no drawbacks to using Equalizer APO that I'm aware of, besides it taxing a tiny bit of your CPU, which is most likely negligible. It should be much better than any physical EQ, as it gives you full graphical control.
Equalizer APO is so powerful, infact, that I think you can make almost any pair of headphones sound like any other pair of headphones, provided there are no extreme peaks or valleys.
Now I know why people do not like APO. It is the UI. Peace UI is not bad, but meh.
It seems bass is not the real problem. The headphone badly needs 1K and 4K zones to be toned down. Is it the fault of the particular piece?
Edit: It has been a few days and I already hate Equalizer APO. Aside from the UI issues, it simply won't stick. If I plug the DAC in a different USB port, I need to reconfig and reboot. If Windows gets an update, I need to reconfig and reboot (I am on Fast Ring, so updates are frequent). And for some reason my streaming service really hates APO. With APO configured, sometimes the player will deny to play any song until I reboot. I am gonna replace that **** with a hardware EQ as soon as I can.
