coinmaster
You can't really say anything unless you've physically tried this component yourself", in which case nobody can say anything about russian components unless they have tried them themselves
Lots of people have tried russian caps and have reviewed them against many other caps. My own experience is limited to Duelunds VS junk but there are quite a few capacitor "showdown" reviews out there and the consistency between their claimed sonic signature and the consistency behind the claims that for the most part the more expensive caps sound better lead me to believe that it is unlikely to be a faslehood. Claiming russian caps are the best caps ever made when you haven't tried all the caps ever made is just an opinion. Especially since you refuse to ever try the expensive caps.
I'm not going to sit here and say it is one thing or the other but the consistent consensus of claims lead me to believe that more expensive caps are usually better.
If the amp draws the same amount of current at all times, the PSU caps do not charge and discharge with the signal.
As far as I understand capacitors will draw current in order to maintain voltage. So if a CCS changes its resistance to maintain a constant current then the voltage must fluctuate. So if the voltage fluctuates then the capacitors will react to the change in voltage and try to increase the current, however I assume this extra current from the capacitors is dissipated as heat in the regulator/CCS. I'm not really sure where this leaves things.
So have a thing charging the caps that able to satisfy the cap, any cap, and have the cap discharge to a load that doesn't ask anything. Then the cap quality becomes moot; nobody will hear any difference.
You still haven't tried an expensive cap to confirm this fact.
Hey guys there's some food for thought in the last 2 posts, any ideas for Implementing?
I've been over all the angles of implementing those mods months ago and there is no good way to go about it since the stock design uses a pcb which means it uses copper traces and the actual implementation would be a mess. If you were to implement these mods you should be prepared to accidentally ruin your amp.
This is why I am forced to build from scratch, it's easier and more reliable in the end.
