MrCurwen
- Dec 26, 2015
As far as caps I think we are open minded for whatever works best.
That's a good attitude to have!
However, there was a categorical claim made about russian caps being poor. At least the categorical claim of them being good has (in addition to a growing pool of DIY guys with extensive history of comparing caps getting on board with them) actual technical specs supporting that at least they are very good.
Anyway I should not be getting more people into the MBGO / KBG / SSG / K73 stuff. The prices are slowly but steadily climbing, and that's not good.
the question of Tubes was going to be my next one.
But not the single triode types.
I was wondering which "dual triode" types tubes would be best for our amps, in which space is the limiting factor. .
I think what you have is good. There are better ones, but they would basically need a lot of redesigning and a bigger chassis. These are very good tubes anyway. Tubes are not the bottleneck; the design is.
You re-made the diagram so you should know instead of asking coinmaster..
What did I ask? I don't understand, please clarify.
It is incorrect to say nothing is balanced.
Alright, a clarification;
It is not very well balanced. It is not balanced to the degree that I would consider "high end". Whether or not that matters to you is up to you, but I'll present my opinion with some reasoning.
We already have force balanced in driver stage by the "common cathode tail".
No.
Forced balance means that the outputs are of exactly equal amplitude in antiphase, even if
1) the inputs are not of exactly equal amplitude (the other input could be grounded for example, so completely nil)
2) the tubes (or tube sections) are not identical in specs (they never really are, +-10% is the norm, +-20% not hard to find)
Without going into a long explanation of how a LTP works (unless there is interest), the forcing of the balance is dependent on what are the relations between
1) the tail impedance
2) the tubes' plate resistance
3) the plate load impedances
Three main rules;
1) the more dominant the tail impedance is, compared to all other impedances in the current route, the better the balance
2) the branches from the shared cathode node (top of the tail) must be as closely matched as is possible
2) considering the previous, the more dominant the plate load impedance is compared to the tube plate resistance, the less the tubes' spec variance matters to the balance
So let's round up and say the plate load impedances are about 4.5 times the plate resistance. The tail is 1.5k, so each branch on top the tail is about 180 times the impedance.
Even guitar amps which don't look for fidelity of any kind, have better ratios. Guitar amps are conserned with balance in some cases, but not because of fidelity but because of power efficiency.
Looking at guitar amps;
Using similar enough tubes like 12AX7 you have 100k plare resistor (bad for linearity, but good for guitar amp) and 10k or 22k or 47k tails!
This amp has 1.5k tail.
It is relying heavily on the fact that the input is perfectly balanced. And, of course, tube selection.
If you put into your amp an signal that is 100% on the other side, and 80% amplitude on the other side, the balance is not going to be pretty.
And also, if you put in a tube that has a (very normal) 10% section mismatch, the balance is not going to be high end pretty.
If you want forced balance, the tail impedance must be AN ORDER OF MAGNITUDE bigger than the COMBINED impedances of both the branches.
Also the plate load impedance should be the dominant one in each branch; 50 or so times greater than the plate resistance. This plays the tube variance out of the picture completely; increases fidelity significantly.
As I said, if this general tube theory is ok in this thread, I can elaborate.
Then, the "tuning" of the opamps controlling DC offset also means power tubes are balanced.
The servos don't contribute to the signal balance between the phases in any way. The servos control DC conditions, they don't affect the signal in any way.
Also they are looped one servo feedback loop per phase. Not connected.
Also everyone forgetting the two 56k that I believe help the opamps achieve zero offset before the headphones are plugged in.
They are dummy loads. They are there for stability and to prevent pops in turn on and turn off conditions and like you said plugging the headphones. Not relevant in any circuit analysis.
Yes, I agree and why Electrolytics are optimal in PSU stage.
So I was wondering why would you put film caps in your PSU to try hear any difference.
Indeed. I used film caps just because I happened to have them (I bought them for a +800 or +900 V supply, so for the voltage rating). I did not expect to hear any difference, for reasons I explained earlier.
A lot of people use very expensive film caps in PSUs because "they are better". A smarter and a lot cheaper solution would be to understand electronics and design, and design around the problem; such as not having the PSU in the signal loop.
If you throw a rock up into the air, and close your eyes, you don't have to see it fall down to know it is in fact going to fall down.
A cap that doesn't charge and discharge in accordance to the signal doesn't affect the sound. One doesn't need to try this out to understand it.
If it happens to affect the sound, then you know you do not in fact have a constant current draw amplifier.
Too much PSU & cap rambling in your posts so whatever cap works for you is fine with me.
I'm sensing I'm going off topic and losing your interest. I'm sorry.
Not shure why you explaining so much about the caps though
Well, when I was trying out different caps for my traditional DIY stuff (mostly single ended and some old timey push pull amps) I was very much interested in how and why the caps seemed to do what they did. General knowledge is applicable to many situations, including modding your amp. This could be off topic though so I'll stop.
"...to big film caps in the PSU would be to add even a simple 2 FET regulator..."
Interesting ideas but hard to follow your point because it seems you are not referring to our amps.
Your amps could have regulators in the PSU. At least designwise, maybe not in the space that is available. Line between DIY and modding is drawn in water. I will of course respect the purpose and confines of the thread so please just say if it's of not enough relevance.
And we already have 2 power transistors operating in our PSU.
Yes. It is a voltage setter, not a regulator.
This is Interesting for other designs and should be made more clear that, that is what it is.
It could be that none of this stuff can be made with the space available or with the PCB. It is for general interest and increased knowledge on how your amp works. If it's off topic I'll leave it alone.
[qoote]So then, what alternatives can we implement for coupling?[/quote]
Output from input stage -> cap (of maybe only modest quality) -> source follower -> direct coupled to output follower grid
This is probably not practically possible in the available space. Anyway if there is interest I'll elaborate.
