Nice ideas. So maybe we could make a list of potential mods together with supposed benefits, difficulties in implementing and so on to give everyone an idea what to go for?
Name the viable ideas.
Coin
you didn't answer me.
Instead you say it's not good English.
Since when are you an English teacher?
Yet again you didn't admit your wrong about slandering me.
2- your trying to "grasp straws" by highlighting my use of the word "we"..
You cant implement this without loosing the "common cathode" connection, responsible for keeping the balanced operation.
It be nice to have some help from you for a change without trying to be right all the time.
I'll go further and say there is not one viable idea to implement in these amps.
To answer that specific question ... NO
Actually, you should try to be as far as possible from the "max temp" of the cap.
A generic rule of thumb ("Arrhenius law") is that you double the life expectency of each 10° decrease from the Max Temp. Originaly, this law is for chemical caps, but you can never be too careful.
For a cap given for 5000H @80°, you can expect to keep it for 10000H @70° or 20000H @60° ...
A generic rule of thumb ("[COLOR=515151]Arrhenius law")[/COLOR] is that you double the life expectency of each 10° decrease from the Max Temp. Originaly, this law is for chemical caps, but you can never be too careful.
Maybe there is a misunderstanding here. I am not talking about max temp but operating temp. These caps have wax inside not outside and seems to require? the wax in a melted state to work best. The same company also makes caps with bee wax with a operating temp of 70C according to the manufacture. I have paper in oil metal case caps in tube amps. These caps do not have paste that can dry out with heat. Like I noticed tube amps need to warm up a bit and in my experience takes about 35 to 40 minutes at 90% best with the various tube amps I have in the past.
But the Ideas presented to me can only apply to coinmaster unfinished amp which can change in design however he wants
Quote: Coinmaster]
"The "common cathode" connection doesn't change.
The Source follower grid drive mod can be done pretty easily, I'll have to make some sort of guide somehow, unless MrCurwen wants to chime in."
Or anyone using an extension box. I don't know who other then Redge is currently using one. At first I wasn't going to recommend the mods due to the layout and construction issues but using a custom PCB actually makes it relatively easy to implement other then the space requirements.
Like I said the impedance mod pot would not be needed so that frees up one space for a voltage/current pot, however you still need more pots and meters so no matter how you look at it you need an extension box.
I actually have no intention of modding my MK6 output stage much after building it, I need something to listen to in between mods, Most of my effort will go into messing with my new design which solves the problem the "impedance" mod tries to solve from the get-go.
As for the MK6 output stage I'll mod it when people here have shown that it is a proven upgrade, maybe other then the "grid drive" mod since it is easily applied and the results can have huge implications for me.
OK,
I will be civil and try to be productive here...
Convince me and I will do it...
Where exactly will you connect the source follwer..
Doesn't each one have to go on a cathode?
Aren't the two triode cathodes connected directly together?
So how will you separate the positive & negative cathodes without eliminating the common cathode design?
Me and my dog (we) would like to know. .
