McIntosh MHA200 Impressions
Dec 1, 2023 at 8:21 AM Post #1,096 of 1,175
Hey Thanatos,
How does the MHA200 compare to the Envy in your signature? I know there’s a world of difference in price but sound wise, power wise, build wise etc what can you say to help me. Thanks
Unfortunately I don't have a MHA200 for a direct comparison, therefore I can't really comment on most things.
I know that the Envy is much more powerful and therefore probably a better fit for Susvara and Expanse/Stealth
Dec 1, 2023 at 2:28 PM Post #1,097 of 1,175
In 2 weeks on our YouTube channel you’ll see a detailed review of that combo if that helps you
Hey Jason,
Quick question for you…
If I wanted to avoid using the volume on the MHA200 could I run my MHA150 into it and my source into my MHA150? That way I can connect to the XLR on the front of the MHA200 and get that tube flavor?
If that’s the case would the MHA200 be used as a preamp and the volume from the MHA150 could control it?
Lastly if all that is correct and true can you please tell me how to connect the two McIntosh amps to get my desired result?
Cheers,
Enrico
Dec 1, 2023 at 3:16 PM Post #1,098 of 1,175
Hey Jason,
Cheers,
Enrico
Hi Enrico!
Yes! You can come out of the MHA150 single ended (RCA) in to the MHA200. Then set the gain control to that detent position on the MHA200 so it’s in unity gain configuration. After that you just plug your sources into the MHA150 and you’re good to go. If you have any other questions or need further understanding just give me a call and I’ll walk you through it. 310-534-9900
The Source AV TSAVJason Stay updated on The Source AV at their sponsor profile on Head-Fi.
https://www.facebook.com./pages/The-Source-AV-Design-Group/153623164648713 http://www.twitter.com/TheSourceAV http://www.instagram.com/Thesourceavdesign http://thesourceav.com/ Products@TheSourceAV.com
Dec 2, 2023 at 4:06 PM Post #1,099 of 1,175
Hi Enrico!
I follow what you say but to be clear the headphones connect by XLR into the MHA200 after the pass through you listed above? Is that correct? If so I will give it a shot 🙏🏼🙏🏼🙏🏼
Dec 2, 2023 at 4:19 PM Post #1,100 of 1,175
This makes me think you tried it with the wrong headphones or something because the sound of this amp is in no way thin or unemotional. Quite the opposite, it sounds full and lush. It's borderline magical with Susvaras. I honestly think the only people that should maybe steer clear of this amp are those that prefer a cooler, more analytical amp.
Does it have enough power for the Susvara’s?
Dec 2, 2023 at 4:28 PM Post #1,101 of 1,175
Hi all.. :)
I am choosing a tube amp for my Meze Empyrean, DAC TOPPING D70s .
I have favorites:
MCINTOSH MHA200
Feliks Audio Euforia Evo
CAYIN HA-3A
AURIS HA2 SE
What do you think is the best choice - for jazz, vocals, pink floyd etc.
To handle Empyrean well. Have enough energy.
I have the Cayin Ha-3a and the McIntosh MHA200 and the Cayin is more linear while the Mac is more tubey. I prefer the Mac
Dec 2, 2023 at 6:48 PM Post #1,102 of 1,175
Yes. Both are phase inverted circuits so you’ll still receive a phase inverted version of balanced
Dec 7, 2023 at 4:15 AM Post #1,103 of 1,175
Hey guys and @TSAVJason , I have couple questions to anyone who might know:
- Anyone been using the MHA200 directly with a diana v2 and care share thoughts?
- Does anyone own or got to listen to both mha200 and wa7 3rd gen and can share insights? As I am lookin to replace the wa7 3rd gen with the mha200.
- Are you using the mha200's volume knob directly?
Thank you : )
Dec 9, 2023 at 2:48 PM Post #1,106 of 1,175
It didn’t work brother. So I come out of the MHA150 RCA that’s marked Preamp or the other one into the MHA200? Which one do I use? Thanks bro
I’ll take a couple photos for you when I’m back in the store later today with both the 150 and 200 connected so you can visualize it.
Dec 12, 2023 at 3:02 PM Post #1,109 of 1,175
Hey Jason,
When you can please post those pics. I can’t get it to work. Sorry to hassle you.
Thank you
Wayne and I are going to do that today for you
Dec 12, 2023 at 5:20 PM Post #1,110 of 1,175
Hey Jason,
Thank you
So I may have forgot to tell you that you need to switch the MHA150 to speaker output to complete the circuit
That is probably why it isn’t working for you yet. Wayne is taking photos for you now to show you the connections but you probably have it correct already.
