I liked the Elite tuning but it just didn't provide me with the level of detail I got from my other headphones and I thought the Empyrean 2 was an improvement in that department so I will look into the Abyss Diana MR.But doesnt matter. It should subjectivly sound better for you than the Elite. Then the Empy II is better for you, if not keep the Elite. That easy
Meze EMPYREAN II
- Thread starter leylandi
Quarzer
- Feb 28, 2017
The Abyss should be the better choice for details. The Empy II is a musical to my ears and not a scalpel.
Therefor have a look at the xDuoo TA-22. It is just a beauty for its costs. I used mine with Elites and Empy II now.
any power issues with the TA-22 and empy?
Quarzer
- Feb 28, 2017
Not for me, but I'm not so familar with highend DAC/Amps. My goal currently is a Cyan 2 with Cayin HA-3A. But that need to wait.any power issues with the TA-22 and empy?
The xDuoo replaced my Burson Conductor 3X Reference.
ckhirnigs113
- May 19, 2005
Were you able to try the Elite with the Angled Alcantara pads? To me, these pads allow the Elite's technical abilities to come through without any downsides. The Hybrid pads are fun, but I use the AA pads 100% of the time now.I liked the Elite tuning but it just didn't provide me with the level of detail I got from my other headphones and I thought the Empyrean 2 was an improvement in that department so I will look into the Abyss Diana MR.
Quarzer
- Feb 28, 2017
One more interesting against the Elite. The Empy II is stiffer and may have a bit more clamping force.
Elite:
Empy II:
Beautiful couple:
Elite:
Empy II:
Beautiful couple:
Slackaveli
How does this sound on Empy2?In one category the Empy II beats any other headphone I heard: Presentation of vocals! This makes me speechless.
The volume, depth, timbre, position, location and how its embedded into the other soundings/instruments is top notch! I'm not talking about vocal-details, its more about how vocals are harmonized with the whole ensemble.
The combination of all those treble details and that crazy bass , plus Juice's vocals are very forward. This is one of my reference songs for testing. Dank, sticky dope.
Nobody (ever) has as many sick unreleased songs as Juice.
rip, King
Did you already try the Empy II with the Elite leather pads?I have both the Elite with hybrid and AA pads and the Empy II here. Will compare them the next 2 weeks. Used the Elite as main for the last 6 months 20 hours the week.
up late
- Feb 19, 2013
is it possible that the headband on your elite might loosened over time?One more interesting against the Elite. The Empy II is stiffer and may have a bit more clamping force.
Elite:
Empy II:
Beautiful couple:
Quarzer
- Feb 28, 2017
No, not the headband. If something got lessened over time then the the carbon bow. BUT carbon keeps his stiffness over time. So can't tell if the elite is always looser then the Empy II, but in my case it is.is it possible that the headband on your elite might loosened over time?
Just changed them for you and have them on the head right now. It is looser for sure. Lets check the sound.Did you already try the Empy II with the Elite leather pads?
up late
- Feb 19, 2013
i meant the whole headband assembly but it doesn't matter - it was just a thoughtNo, not the headband. If something got lessened over time then the the carbon bow. BUT carbon keeps his stiffness over time. So can't tell if the elite is always looser then the Empy II, but in my case it is.
Quarzer
- Feb 28, 2017
rip, King
The vocals still awesome presented. The bass is kicking really nice, beside its not my taste of music. But overall clean representation. If you want to have the bass kicking you out of your socks, let me tell you, the Empy II doesn't, instead it let you grove
Quarzer
- Feb 28, 2017
Sure. But the leather is not producing the clamping force and stickiness, its only the carbon bow. And carbon is stick as ****. I really think the Empy II is a bit more solid and provides more clamping force then the Elite. I wear the Empy II yesterday 6h straight away and I have big issues with comfort. My ears or my side of the face are hurting really fast. For example I couldn't were the D8KP more the 1 to 1,5h straight away. You fell the Empy, you are aware of that there is something on your head. But I also never forget the Elite. So for me both are on the same comfort level. The Elite is losser the Empy II thighter but I enjoy the new hybird pads a lot. These are awesome on both sides: Comfort/feeling on the skin, as well as sound.i meant the whole headband assembly but it doesn't matter - it was just a thought
Quarzer
- Feb 28, 2017
Ok, I think the leather pads of Elite have more punch, but as well more blurring and less clarity. In the first 10 minutes I like the hybrids of the Empy II more then the leather Elite ones.Did you already try the Empy II with the Elite leather pads?
Comfort is on par. On the skin the hybrids are nice, but because of the smaller hole there not that much space for the ears. Its not annoying but less airy (not the sound).
How is the sound of the Empy II Duo (hybrid) pads on the Elite? Vs Elite hybrid pads and Angled Alcantara?
