Not messing further with a setup is a good thing, right? My MZ3 is on for hours everyday and I haven’t futzed with the tubes in quite awhile. RCA 6201 blackplate and 12SN7GT clear. I forget the exact years, but they’re older than I am so 60s, maybe even 50s. I thought I was buying a preamp, but I think I use it that way least of all. Paired with ZMF VO is my favorite, so quick, but what continues to surprise me is how well it behaves as an integrated. I know it’s maxing out at less than 1/2W into 16 ohm Zu speakers, but it sounds so good and gets plenty loud. Not broadcast volume, but I usually tap out well before 90 dB-C anyway. Need to protect my hearing for the long term.Evening Gents,
I hope you are well? Just checking in to see how your respective journeys are going?
microZOTL 3 by Linear Tube Audio. True High End Audio.
- Thread starter jamato8
I’ve been told that’s a killer combo. What speakers are you driving?
AussieMick
Focal Kanta No.2. Innuos Zen MK3 streamer, Chord M Scaler/TT2 DAC.I’ve been told that’s a killer combo. What speakers are you driving?
AussieMick
Australian/New Zealand people, I have an MZ3 for sale. PM if interested. Trying to raise the dollars for a Z40+
- Oct 18, 2016
I approve of this upgrade.Australian/New Zealand people, I have an MZ3 for sale. PM if interested. Trying to raise the dollars for a Z40+
FWIW, I use a MZ3 as a preamp with a Z40+ and it is a super sweet combo that I cannot imagine will be bettered in my system. Maybe if you can find a used Z40+ like I did, you could keep your options open.I approve of this upgrade.
Has anyone found the 200-step "Hi-Res" volume control to behave differently from the standard 100-step volume control?
With the high-res, the increase in volume as I turn the dial up seems more uneven, and at lower volumes the sound seems tonally disbalanced.
Even at a fixed normal listening volume, I'm not sure the sound is the same in both cases: it seems more "forward" when using the standard volume control.
jamato8
Have you asked LTA about this?Has anyone found the 200-step "Hi-Res" volume control to behave differently from the standard 100-step volume control?
With the high-res, the increase in volume as I turn the dial up seems more uneven, and at lower volumes the sound seems tonally disbalanced. Even at a fixed normal listening volume, I'm not sure the sound is the same in both cases: it seems more "forward" when using the standard volume.
I probably should, yes. Was just wondering if anyone has experienced something similar.
I’ve never noticed a tonal or presentation change. It’s still the same resistor ladder, just with more steps I think. The curve seems different though, it isn’t just 2:1.I probably should, yes. Was just wondering if anyone has experienced something similar.
skhan007
Didn't even know this existed. Something they're putting on newer MZ3's?
The curve is definitely different. On hi-res I listen at 120/199, so 60%, but on the standard control the same volume is around 35/100, so only about 35%.
Leading up to the 120/199 on the hi-res setting, say when I am at 50/199, I get this "ghostlike" sound profile, where there is no bass at all, just upper-mids and treble. Increasing further to listening levels, the bass and mids come in.
