microZOTL 3 by Linear Tube Audio. True High End Audio.
Feb 11, 2024 at 9:03 PM Post #1,157 of 1,183
I can double check with a proper A/B test, but around volume level 25-27 with 300 Ohm headphones and about volume level 35 on the Abyss 1266.
..... ?? ..... I am usually volume level 55-60 with ZMF Atrium / Atticus / Auteur / Eikon, 50-55 with Focal Clear OG, 45-50 with Grado PS2000e .....
Feb 11, 2024 at 9:05 PM Post #1,158 of 1,183
Feb 12, 2024 at 8:00 AM Post #1,159 of 1,183
So after researching a bit and reading more on my RME ADI-2 DAC, it appears I had it set up for about 3.5v output. After going into the settings and making some I/O adjustments to have it recalibrate the single-ended outputs to about 2v, my comfortable volume with the Abyss is about 50-55 on the MZ3 dial. This is about 63 dB listening volume, according to my dB meter. Not sure how loudly you guys listen to your music, but in summary, these Abyss headphones require about 10 clicks increase on the MZ3 volume knob.
Feb 12, 2024 at 11:04 AM Post #1,160 of 1,183
... at 3.5v SE output, I am surprised that MZ3 / WA22 did not experience 'overload compression' ... šŸ˜³
Feb 12, 2024 at 11:26 AM Post #1,161 of 1,183
I have the preamp version and fed Preamp signal and you would be surprised how much amount it can take before clipping, very versatile amp.
Feb 12, 2024 at 11:42 AM Post #1,162 of 1,183
I asked about the max input voltage prior to purchase of my MZ3.
ā€œThe maximum voltage is greater than 5V.ā€
Of course Iā€™m not entirely sure why I asked that now, but I was able to find the email.
Feb 12, 2024 at 11:52 AM Post #1,163 of 1,183
My chord qutest has output settings for 1v, 2v, 3v. Should the setting have an impact other than how high I turn up the volume on the mz3?
Feb 12, 2024 at 12:00 PM Post #1,164 of 1,183
I certainly havenā€™t noticed any. Rob Watts chimed in on the Qutest thread and had some reassurance about it as well. I run 3V because theoretically it should have better S/N over the cable run, and I sometimes use my MZ3 as an integrated. Every little bit helps. Even though I know itā€™s perfectly okay, I still get nervous when the volume reads above 75.
Feb 12, 2024 at 12:25 PM Post #1,166 of 1,183
I think the MZ3 is likely built like a tank, as I hear no change at all in tone/frequency with 2v or 3.5v. Only the volume compensation is noteworthy. I'll play it safe and keep it at 2v. I also have this same DAC using balanced outs to my Woo WA22 and according to the manual, the balanced outs are 6 dB higher (i.e. double the single-ended output), so when using that amp, I need to change/lower the DAC's I/O setting to achieve 2 v. Not a big deal at all, but something to keep in mind when I switch between these two amps.
Feb 12, 2024 at 12:31 PM Post #1,167 of 1,183
Same experience on my end, I have balanced inputs on mine and I do hear a bit better details and clarity that than RCA inputs. They use Lundhal transformers to convert balanced to RCA and not sure if it plays into the equation a bit, its not night and day but one can hear the difference.
Feb 24, 2024 at 5:04 PM Post #1,168 of 1,183
I've decided after a bit of experimentation, that my DAC signal doesn't need to be the full 2 v (or higher), as I like to use some of the EQ features. So when those are activated on my DAC, I believe there's an output boost to the MZ3. Thus, my DAC has a dBr reading of -22.0 and I crank up the MZ3 to about 70-75. This produces around ~70 dB on my headphones, which is a comfortable listening level. My previous settings I was experimenting with resulted in 2v and volume of about 40-45 on the MZ3 and at 3.5 v, a volume of about 25 on the MZ3. Using Abyss headphones, by the way. They need a tad more power.
Mar 3, 2024 at 5:04 PM Post #1,169 of 1,183
Evening Gents,
I hope you are well? Just checking in to see how your respective journeys are going?
Mar 3, 2024 at 5:18 PM Post #1,170 of 1,183
