Riverflow
That was a shock to menever knew you would get points for aesthetics value!
Jonathan c has given me a idea a silver balanced cable that matches the headphones better for xmas
I am no expert but have you tried swapping the tubes over to see if the problem moves to the other ear?i am getting a sound like wind going thru one side of my headphones then it goes away, very annoying. Bad tube? what can be the cause?always thru the same side
… does this happen with all your headphones? (Trying to rule headphones out as the issue…)i am getting a sound like wind going thru one side of my headphones then it goes away, very annoying. Bad tube? what can be the cause?always thru the same side
doesnt happen on my other amp. does happen with all headphones. Just switched tubes around and the sound moved to other ear. looks like i may have a bad tube.eventually the wind noise does get quieter but doesnt totally go awayI am no expert but have you tried swapping the tubes over to see if the problem moves to the other ear?
Also is it the same headphones and cables
You could try a different amp or dac to eliminate one or the other?
… when does the wind sound appear? how long does it last before going away?
If you are using adapters: when you switch the tubes, do the adapters ‘go’ with the tubes?doesnt happen on my other amp. does happen with all headphones. Just switched tubes around and the sound moved to other ear. looks like i may have a bad tube.eventually the wind noise does get quieter but doesnt totally go away.
It’s the tube(s). Have you tried different suitable tubes in the adapters?no, adapters stayed and moved tubes. but noise switched sides
What were the last pair?new Mullard 12au7, sound pretty good straight out the box. hopefully these last longer then my last tubes
