ozz
- Jan 23, 2007
Still rocking the Asgard 3/Multibit card through Focal Clears and never looked back it makes all my music satisfying to listen to.
There is a new one? Didn't know about that, so yes, this is the one that shipped with the A3 at the initial launch.Is that the new Multibit card or the OG one? Curious if there's any sonic difference or voltage output difference.
My little Magni 3+ at the office is now 4 years old and has recently developed some weird behavior: big popping at the left channel when plugging anything into the jack, and channel imbalance (-3dB in L). My work-around has been an attenuator -- also for the obvious reason of more granularity in the volume pot -- and somehow that voltage divider addresses the channel imbalance, but I fear that I should retire the little fella ASAP before it decides to play Kamikaze with one of my transducers.I went from a Magni 3+ to the Asgard 3.
Asgard will have no problem with either. I have 600Ohm DT880s that run of it.Is it better to run my 250Ω DT770 or my 80Ω DT770 on my Asgard? In terms of Asgard lifespan, musicality.
Why do these things (headphones) come in different Ω-age?
I am also curious to know the answer to that question.What has the Valhalla 2 got over the Asgard 3 that made you sell it? What cans are you using with it?
I've downsized, I have to two pairs headphones now, Sennheiser HD600 and Beyerdynamic DT880 600 ohm. It's simple, I like the way the Vahalla 2 sounds. I like the way it sounds with my high impedance headphones. I had sold my low impedance headphones by the time I had bought the Vahalla 2 so I cannot comment on the Vahalla's performance with low impedance headphones. I sold my Asgard 3 because it was sitting unused.What has the Valhalla 2 got over the Asgard 3 that made you sell it? What cans are you using with it?
