GlenAppleton
I'll let others comment on difficult to drive IEMs, but as for 3.5 vs. 4.4, I can hopefully provide some clarity. The "single ended" 3.5mm connection on most headphone DAC / AMP gear has a shared ground between the right and left channels, where the 4.4mm "balanced" connection has a separate ground for each channel. While it's not proven to provide any more clarity / purity in the signal, many claim that the separate ground does do so to at least some minor extent. On the gear I have that is fitted with the balanced connection, the sound path is engineered with separate amps for each channel, and therefore provides more power output which helps with harder to drive headphones / IEMs. Typically I use the 4.4mm balanced connection for planar IEMs that require a bit more power to get their full potential flowing.@Shanling Hi, I want to know if the UA4 can power my Simgot EA1000 and Yanyin Canon 2 easily with only the 3.5mm? Also, what are the benefits of the balanced 4.4mm exactly when compared to the 3.5mm? I'm new to this audio hobby, so I'm confused between these two audio connectors. Thanks in advance.
Simgot EA1000 specs: 127dB/Vrms and 16 ohms
Yanyin Canon 2 specs: 112dB/Vrms and 40 ohms
Hope this helps explain it a little better.
