Which method did you try ? Manual ADB & uninstall commands or the above mentioned
adpappcontrol program ?
Getting rid of bloatware certainly improves performance and battery life, but an increase in Sound Quality ? I can't believe that.
It doesn't make sense either from a Sony engineer perspective. They spend years and years optimizing the SQ of their DAPs
, so why would they allow to have bloatware having an influence on SQ ?
The answer is very simple, Sony cannot remove these google "bloatware" as part of their licensing agreement with Google to use their Android 11 OS. They must ship the device pre-loaded with google apps.
https://www.android.com/certified/partners/
Like how Sony handles the EU Volume Laws, Sony is always in compliance with the prevailing laws and standards.
Other DAP manufacturers are using their own custom open-android or do not necessary follow Google's agreement in full.
Every program or services installed and running on the equipment will increase the CPU usage, as in they will occupy a slice of the available computing time as threads, which the thread scheduling is controlled by the operating system's task scheduler.
https://en.m.wikipedia.org/wiki/Computer_multitasking
In a nutshell, the more programs running, the more interrupts will be generated and thus placing more processor load/memory resources on the system. This may increase the background load of the cpu, generating more heat, increase power consumption, taking away valuable processor cache space and increase system response latencies.
How much of an influence will additonal software have on sound quality? Well it depends on where the bottleneck to the sound quality lies within your entire audio chain.
For example, if you are using some bluetooth headphones using SBC codec for transmission, by debloating the DAP, there's not going to much difference to the end sound quality as the bottleneck lies with the bluetooth codec rather than the OS or DAP.
In a high quality playback device that has ultra low jitter clocking and relies on high precision accurately timed electrical pulses to generate extremely high quality sound output, everything in the chain matters which includes the software.
Also the bottleneck might lie in the end listener, not everyone can notice the difference, you either have to level up your hearing kung fu or be very lucky to be born with very golden ears. like in the case of this boy:
