paradoxper
I'm well aware of his blog. I'm also well aware of his disappearance. So....
You can express your opinion that the LCD-2 out of the O2 can go no further. I will simply disagree.
The Magni/Modi is a cheaper and better alternative, IMO. And there are far more amps out there that outclass the Objective's SQ, again IMO.
Objective2/ODAC is fully capable to drive LCD-2 to their full potential, you can even read up full details on nwavguy's blog (use search button, he even talked about current with LCD-2).
If you look about high-end professional amps like Fostex HP-A8, DAC1/DAC2, O2 etc., none of those output 10W or so... Why? Because it's overkill and you are only getting distortion with overdriving your headphones. Actually, O2/ODAC specs are very similar to both HP-A8 and DAC1/DAC2... It's a SPECTACULAR piece of gear.
EDIT: Not to say that the version with 1/4 headphone out and better internal connections is even better...
