What about comfort, ear pads and sound leak in the HD5500?, I think that I'll get them because seem the best option that I could find for that price in my country.
Didn't realise this thread existed so this was previously posted on another thread. Takstar has a new planar, but so far, haven't been able to find out anything except its own website link.
1. Take off the metal ISK label on the sides of the headphone. The sound stage is better and more airy.
2. Open the cups up, in the middle there is a small circular area that is not covered by felt and covered by black foam. Cover this area up with felt. Those stick-on felts patches to prevent chairs from scratching the floors has a perfect size for this. I happen to punch a tiny hole through the middle (1-2mm). This got rid of the slightly boomy bass and there is no more bleed into mid-bass. It doesn't make it a closed headphone. The headphone still breathes but there is more restricted air movement to control the boomy bass.
3. There is no buzz like the Pro 82 at the low frequency sweep. Could be because of the better power handling or the bigger 53mm driver.
4. The velour pads are way cooler than pleather pads.
Really enjoy this pair of cheap headphones but I think 3-5 Khz area can use parametric EQ.
Wish someone could properly measure this headphone (hopefully with my mods as well to objective tell if it really made a difference! LOL)
After a decade and relocation to NA I reaquired a used HyperX Cloud ii/Takstar Pro 80. $25 Sound just as I recall. Part of the stable of audiophile giant killers from the early 20-teens.
For closed cans to do better you need to spend $250 or more.
Still made as the HyperX or ISK HP2011. No noticeable sound loss due to Mic hole open as HyperX are gamer sets with a Mic.
Original CAL! Aurvana from same era are nowhere near as good as Pro 80 but in same audiophile detail target sq.
Pro 80s are a discontinued classic. When you find a working used pair, buy them!
It's the exact same story with HD 5500. If you want to go with something other than the flagship PRO 82, than you should consider the HD 5800 or the TS-450. Both of those are better in every aspect than older, non flagship, Takstar models.
I ordered their most recent release - the HD 6500. It should arrive soon and I'll be able to give feedback on it.
I've never listened to the Takstar HD6500, but I would expect the Takstar HF 580 (planar) headphones to sound better.
(I own the Takstar HD6000 & HF 580).
The Drop (Massdrop) Hifiman HD5XX are really good for their $180 price. https://drop.com/buy/drop-hifiman-he5xx
