all999
Is this player can be used as an USB dac ?
yes it seems there DAC feature
I don't think so.
I heard both the Onkyo DPX1 and thebit Opus#1 at a shop just now with the balanced output. The former has a darker background, more air and sounded sweeter, thebit is more immediate, to the face, better bass and texture, more forceful sounding and seem to have a strong driving power into the Shure 846. The impression is also the same using AKGK712 on the single end output. My take is if you are into rock and live pop thebit is the way to go, the DPX 1 is great for jazz with better layering of sound but less impact, your mileage may vary.
Does it support DSD ? It lists it as a format on their product page but says also 24/192 max. Does it downsample ?
Also what version of Android and can you install 3rd party ?
