I use my GSX-mini as a preamp to my Tor Audio Balanced. It gives me more volume and it sounds a little better.I’ve had my Tor Roger for nearly two weeks now and feel I can give an honest review on how it sounds.
To start, my chain:
Cayin iDAC-6
Cayin iHA-6
ZMF Verite closed
So how does the Roger sound?
Fast, detailed, holographic although gain is limited with some tracks and the amp could do with a little more headroom. I should add that I swapped out the stock tube for a PSVANE CV181-T-M11/2 which I feel adds note weight and a greater sense of space vs the supplied stock tube.
If I swap between the Tor & Cayin amp the Cayin sounds more compressed vs the more open holographic sound through the Tor. Vocals on the Cayin sound a tad closer with the Tor sounding a little airier in presentation. Detail I would say is on par and I prefer the sound of the Tor for sure. Bass weight is more palpable with the Tor and you defiantly feel it with the mids adding that holographic sound you get with the best tube amps.
The treble feels and sounds airy and real with no obvious roll-off. Soundstage and depth perception is fantastic, and you get a real sense that you are there in the room with the music. With the ZMF’s you forget more that they are closed back which is something I couldn’t get away with when listening through the Cayin. With the Cayin I always feel as if the presentation has limits when it comes to boundaries but with the Tor the sound feels so much more open and expressive.
This is not my first tube amp and I bought and sold a Cayin HA-3A which on reflection didn’t sound that tubey for want of a better word. It had stacks of gain but just felt a little lacking when it came to giving you the warmth and holographic presentation you expect with tubes.
Streaming with Tidal there is a headroom issue with the amp and when playing ‘The Cream of Clapton’ I can get the amp to max volume without it blasting my ears! For the same volume on the Cayin I’m at around 11 o’clock so headroom is lacking for sure. I would say I’m usually somewhere between 1 o’clock and 3 o’clock with the TOR and my only critique would be this.
I should add that from order it took around 5-6 weeks to receive the amp and it came well packaged in a large cardboard box with plenty bubble wrap. Fit and finish is excellent with no wobbly parts although you do need to buy a mains lead and interconnect which is no big deal.
To conclude the amp is definitely a keeper and beats the Cayin with regards to sq I just wish there was more gain.
