TRINITY - PHANTOM Series - New thread + WORLDS FIRST PUSH PULL HYBRID IEM!*
- Thread starter Bobtrinity
Midgetguy
Damn, was looking forward to seeing what a Trinity-made 6-BA was gonna be like. But I trust Bob's ability to make a good IEM so now I'll be looking forward to the Phantom Master!
@Bobtrinity, so since you listed the that the Phantom Master is gonna be similar in form factor to the Sabre, are you able to give any slight specifics? Like, by similar, is the Phantom Master only going to be slightly larger than the Sabre? And for reference, can you tell me what the diameter of the Sabre shell is?
- Apr 9, 2015
@Bobtrinity
I will get back to you on Monday with some measurements.
The diameter will only be marginally bigger than the Sabre.
Podster
Why do I feel like I'm going to get into trouble in here
Neotribal
- Oct 5, 2015
( ͡° ͜ʖ ͡°)
HiFlight
How can I say no to the Phantom??? Easy, I can't!
mikaveli06
- Jan 4, 2012
Do you feel the master will be able to be driven by your Bluetooth cable, or will it need more power?
dullknives
- May 9, 2015
@Bobtrinity any chance these filters (specifically the long length) will retro-fit the atlas? the sabre pic looks like the same design but possibly a wider diameter. the delta filters are just too wide for me personally while the atlas filter's narrower diameter feel fine.
merc05
- Dec 2, 2015
Well this will save some money haha.
REALLY happy to see you mention the filters come in two lengths - my main criticism of the Atlas is that fit depth is limited. Ergonomically its a great fit, IF you have the right tips to get the depth you need - and for me, thats not any of the included tips.
Confused about the Air though, you say nothing has changed but that was originally a dual BA, wasn't it?
It could have been me who mentioned the filter depth on the Atlas as I've been having some issues with fit and suggested that (being used to deeper fitting IEMs like some of the Etymotic range) it could be something to do with the length/width of the Atlas filters. It's great to see Bob listening to customer feedback, I always think that's the sign of an excellent company!
Sign me up for a pair of the Phantom Master
I believe Kumitate Labs from Japan beat ya to the first push/pull hybrid with their REF model. Regardless, that Phantom Sabre looks mighty interesting.
swannie007
- Oct 30, 2013
It would sure be nice if the longer filters fitted the Atlas' as that is my only concern with them. I am not used to a shallow insertion earphone and find it difficult to get a good seal without discomfort to my ear canals as I have to push them in as far as I can and can only use them for a limited time compared to my other items. Here's hoping.
Bob, these are sure looking good mate and I can't wait to hear them.
Cheers from Oz.
Cheers from Oz.
Bob A (SD)
- May 11, 2003
The Sabre STILL has my attention. The new Master as well. VERY interesting developments!
hongky
- Mar 13, 2013
Comparison between Sabre and ATH CKR series would be interesting. Can't wait for initial review.
So there will be no Phantom Pure with only BA drivers anymore?
- Jan 10, 2016
Wonder how the Phantom Master is compared to FLC8S. Based on what I have read, Phantom Master will be a mixture of ATH-CKR10 and ATH-CK100 pro
Total: 6 (members: 0, guests: 6)
