Just start out with some well made cables as short as you can use. I like worlds best cables as the cable and the connectors are all good quality https://www.amazon.com/Units-Balanc...234543&sprefix=worlds+best+xlr,aps,295&sr=8-8What would cables would recommend for pairing these two
Violectric V222 and V202
- Thread starter Ichos
- Tags
- v202 v222 violectirc
Pharmaboy
I use Lush Phasure (version 1) with both my DACs, one of which powers the V281, and the other of which powers the Wells Milo. I'm a fan of these slightly warm, musical sounding USB cables.What would cables would recommend for pairing these two.
Plan on buying several of these as soon as I figure out exactly what I need and how many of them. I see you watch Z reviews alsoJust start out with some well made cables as short as you can use. I like worlds best cables as the cable and the connectors are all good quality https://www.amazon.com/Units-Balanced-Microphone-Amphenol-Connectors/dp/B07MQDCFDB/ref=sr_1_8?crid=2PB6QGBW42N64&dib=eyJ2IjoiMSJ9.Wyeha2KJjWMYJZiFIw7xgwFp3iVwEpp0kfUOmxXS_cUC9Dkd7PHp6oJcVgPZMnn8m8ZSDBvos0NbObK5fjKj1sm7FMoV3sMRkVN3OnmBBkTeMSHE7MyiCjwMkKeavEB79wdY4uio4nNn9gmpFuvAgF6iC8zkUncAi5dgzekpq825evBrcWP2ieiJGnIFTWLLyJwzJwO3AJeUYgKttLfYHGiPrCk_5Jng8et8KgoXZKzGkan52mxVA9PBERxFNDqgyIPCMZbN4vpJDPbhBPzTtRl8XUqzNOea5FXPWBRLtPc.2NGsL0cQm9MxMGzF-hsY6mq0-5wv5i2oiFdp6l9o3yI&dib_tag=se&keywords=worlds+best+xlr+cable&qid=1711234543&sprefix=worlds+best+xlr,aps,295&sr=8-8
No not really a fan of his style of reviewing, I prefer reviewers like currawong or passion for sound. The cable recommendation is because I make my own cables and for interconnects I use Mogami W2534 cable and Neutrik connectors and those worlds best cables only cost a little bit more than the parts themself. If it wasn't for me wanting to make exact size cables I'd buy those ones. Also they are good quality oxygen free cable with good shielding and a good gauge for short interconnects so I view them as a good base standard to then try to judge "better" cables against if you get into that later.I see you watch Z reviews also
Has anyone listened to V222 with HE1000se? How does it sound? Does V222 have synergy with HE1000se?
Enquiring minds would like to know.... How did that v550 work out for you?Just purchased the v550 I really hope it takes my iems to the next level
It worked out like you wouldn’t believe.. the resolution it brings to everything is nutsEnquiring minds would like to know.... How did that v550 work out for you?
I just ordered a v222 earlier this afternoon. I first heard the v226 being used as an Amp with the Chord Qutest at CanJam SoCal 2023. I hope I love the v222 with my TEAC UD-505 as much as the Qutest/v226 Combo. I guess I'll know in a few days if I need to make that leap to the v550.It worked out like you wouldn’t believe.. the resolution it brings to everything is nuts
Did you use the Sony DAP in your signature as the DAC? If so what was that listening experience like with the Fir Xenon 6?
Yes, I use the Sony gold brick as a source/dac and it is incredible with the firxe6 phenomenal synergyI just ordered a v222 earlier this afternoon. I first heard the v226 being used as an Amp with the Chord Qutest at CanJam SoCal 2023. I hope I love the v222 with my TEAC UD-505 as much as the Qutest/v226 Combo. I guess I'll know in a few days if I need to make that leap to the v550.
davehutch
- Aug 10, 2009
@fdg Can anyone confirm if the V222 is a Class-A amplifier please?
It is not. Class AB.@fdg Can anyone confirm if the V222 is a Class-A amplifier please?
Class A generates a lot of heat
Jagamov
Interesting discovery this weekend: I found you can use the XLR and 4.4mm output at the same time. Don't know if that's a good idea or not, but it handled it like a champ. Did not try the 1/4". In fact, I don't even know if it works...LOL
davehutch
- Aug 10, 2009
ThanksIt is not. Class AB.
I'm interested of the Violectric V222, but is it really worth the money to upgrade from the RME ADI 2 inbuilt headphone amp to this amplifier, seriously?
Total: 17 (members: 7, guests: 10)
