Me toomine is as straight as the ones
Violectric V222 and V202
- Thread starter Ichos
- Tags
- v202 v222 violectirc
Same here but I purchased mine from Violectric's store on Amazon.No, mine is as straight as the ones on my other Vios…
alonwa
- Nov 5, 2014
Maybe it's not snatched into place, as it's a bit recessed. I'll take a look at it tomorrow to see if I can fix it myself (I already removed the cover when it arrived in order to switch the voltage)
Is the voltage not set to 115v for units sold in the United States by default?Maybe it's not snatched into place, as it's a bit recessed. I'll take a look at it tomorrow to see if I can fix it myself (I already removed the cover when it arrived in order to switch the voltage)
alonwa
- Nov 5, 2014
It is, but I'm not in the US, so I needed it to be set to 230vIs the voltage not set to 115v for units sold in the United States by default?
alonwa
- Nov 5, 2014
Fixed it myself. Removed the cover, saw the the XLR connector was not properly inserted into the chassis in its upper part, disconnected an internal cable that was on the way, inserted the connector into its proper place in the chassis (needed to apply a little force for that), reconnected the cable and closed the cover. Now it's perfect. All in all it took maybe 10 minutes. As soon as I reliazed that I may be able to fix it myself, I wasn't going to wait for tomorrow. Thanks for reassuring me that it wasn't OK as it was. Anyway, this is poor QC on Violectric's endMaybe it's not snatched into place, as it's a bit recessed. I'll take a look at it tomorrow to see if I can fix it myself (I already removed the cover when it arrived in order to switch the voltage)
jkteddy77
- Jan 18, 2015
Just got the Mjolnir 3 to compare to V222. Pairing and initial thought first 20 minutes after being brain-burned to V222
Headphone: HE1000 Stealth balanced input
V222+ Denafrips Ares 12th-1: More Intimate imaging. Wider soundstage and smoother mix between the instruments. More Bass, warmer/musical, slight treble sparkle
Mjolnir 3 + Bifrost 2/64: Smaller overall soundstage, but less intimate imaging. So, Imaging is more accurate, but harder to pick out in 'space'. Faster Transience, really Punches without delay on bass hits whereas the V222 just booms. Less Bass boom and much less mid warmth. Vocals less forward, all instruments very in-line, not as holographic. Leaner-neutral overall. More accurate treble with no sibilant-sparkle, yet it comes across more fatiguing without the warmth.
Mjolnir 3 + Ares 12th-1: Wider stage than Bifrost 2, but much thinner and flatter. FLAT. A little more accurate treble as BF2/64 sharpens it. If you want ZERO color this is the way. Not my preference, but any HE-1000SE owner's dream.
Quite in-line with Wave-Theories review. Going to brain-burn the MJ3 for a bit to develop less bias.
Schiit YGGDRASIL, V800 or Geshelli sounds like a good next ones to try. Surprised by the Bifrost2/64 is so neutral, thought it may have been a perfect match.
Maybe time for a 'catch and release' on the Mjolnir 3........
Have you tried connecting V222+Bifrost 2/64?Just got the Mjolnir 3 to compare to V222. Pairing and initial thought first 20 minutes after being brain-burned to V222
I have Bifrost 2/64 + HE-1000SE and I have a choice - V222 or Mjolnir 3, I don’t know what to choose.
Hatmann
- Jul 28, 2002
I have been trying that combo and V222 and Bifrost 2/64 is a magical pair — highly recommended.Have you tried connecting V222+Bifrost 2/64?
jkteddy77
- Jan 18, 2015
Personally feel the BF2 actually makes it a bit TOO thick sounding haha. I find the Ares 12TH-1 being R2R and with a larger soundstage and flatter signature actually makes the V222 sound a lot more holographic and dynamic and not cramped-intimate - albeit at the cost of the BF2's bass impact.I have been trying that combo and V222 and Bifrost 2/64 is a magical pair — highly recommended.
jkteddy77
- Jan 18, 2015
BF2 is a little thick sounding in my chain with V222, it HAS to be in NOS mode or it gets "stuffy" and all the Planar air is gone.Have you tried connecting V222+Bifrost 2/64?
HE1000SE you will absolutely want the MJ3, IF the reason you got the SE was to chase accurate neutrality.
Watch Wave Theories review, in which he does talk specifically to the V222/MJ3 paired with SE at some points.
The Flex MENTOR is a 3rd competitor that apparently tops both V222 and MJ3 for the same price, and it's more grandiose and neutral than each.
jkteddy77
- Jan 18, 2015
PM me in a month, I may be your catch...Schiit YGGDRASIL, V800 or Geshelli sounds like a good next ones to try. Surprised by the Bifrost2/64 is so neutral, thought it may have been a perfect match.
BF2 is Lean, both paired together create the perfect "Schiit Timbre" BUT when comparing to the V222, the most musical and romantic solid-state amp at this price-range, it's much 'cleaner'
Hours longer I'm finding MJ3 in High gain + BF2 in OS mode brings the color back but not close to the V222.
I may hold you to that!PM me in a month, I may be your catch...
BF2 is Lean, both paired together create the perfect "Schiit Timbre" BUT when comparing to the V222, the most musical and romantic solid-state amp at this price-range, it's much closer to neutral in the mids. As I noted, the Ares makes it a lot flatter than the BF2
So you just testing or not happening with your DAC?
Their are a lot of really good amps but finding a good DAC is fools gold, I was told.
Have you tried the V800 yet?
Thanks for the advice, I understand, I need MJ3.BF2 is a little thick sounding in my chain with V222, it HAS to be in NOS mode or it gets "stuffy" and all the Planar air is gone.
I always choose NOS mode on BF 2/64
Flex MENTOR would be too bulky on my desk
Total: 16 (members: 5, guests: 11)
