Vs the Violectric V380² (€2300)
The Violectric V380² is another excellent sounding all-in-one unit with four ES9026PRO DAC chips (two per channel) where the engineers have managed to combine top tier technicalities with immense musicality.
There are three digital inputs (USB, coaxial and optical) and two line level inputs but it doesn't have wireless Bluetooth connectivity and it doesn't support MQA decoding.
You get three headphone outputs with three different output jacks (4-pin XLR, 4.4mm and 6.35mm) and two line outputs (balanced and unbalanced) that can be set as fixed or variable.
The headphone amplifier is more powerful with 5000mW50Ω and 21VRMS into 600Ω.
No remote control for the V380² but it has a higher quality potentiometer with a massive aluminium knob.
Build quality and appearance are on the same excellent level for both
Can't find your comparison.
Both sound equally impressive, engaging and musical with some differences here and there.
The V380² is just a little cleaner and transparent with a more open and layered sound presentation.
They share the same harmonic wealth and naturalness of timbre that gets a touch more convincing in the case of the Violectric.
Soundstage is a bit more holographic in the V380² while it retains the same level of performance both from the DAC and headphone outputs.
Finally the V380² has the more visceral and fuller bass texture while it is more dynamic but fading is just a bit faster than the more relaxed and naturally decaying CMA Fifteen, especially in the treble.
The battle is fierce and it can continue till the end of times without a winner
