Low gain. Per manual (at least for RCA analog inputs) max Vin Vrms is 5V. On high it is 2.1. So, 6V is still a bit hot. Does Lina have 2V or 0.6V output options?I agree with all the positive comments about Aperio. It's up in the rarified air of just a hand full of headphone systems. I am looking to pair my Lina DAC to Aperio. I have some set up questions.
1- Lina output set to 6V what is the proper gain to set Aperio input to. Low or High?
2- Lina volume control set to unlock on should the volume control in Roon be Fixed?
Any thoughts would be appreciated
If you cannot lower below 6V I’d enable variable volume control on DAC and/or in Roon to set output slightly lower and then fine tune volume on the Aperio.
