artemart
- Apr 27, 2013
If the tubes are NOS, they will almost certainly test within 10% of each other, especially if they were made around the same time. I wouldn't worry about it in the slightest. Matched pairs are pretty overrated. I have never seen someone say "I put in a set of x tubes, and couldn't stand them. They obviously weren't matched." I've put in tubes, same manufacturer, but different construction, and thought they sounded great. It's all in the eye (ear) of the beholder, but especially for same tube, never used, you don't need to worry about it being tested or not. If you were to test your tubes, they would test as matched. And what is matched anyways. If a seller has a pair within 2%, they'll tell you that only tubes within 2% are truly matched. I've seen 2% listed as "super matched," I've seen 5% said to be the gold standard for matched, and 10% as well. And again, to date, I've never seen someone say they could tell the difference.
Thank you for this helpful information, this means that I can buy a single 6F8G tube to get a set of 6F8G tubes.
I was given a set but due to USPS poor handling of the package one of the tubes broke (picture below).
