I’ve been doing some looking into the topic of the Tungsten myself. First, here is a good resource for calculating this stuff with published data for lots of headphones and amps:
https://headphoneresource.com/
If you want pretty much ideal sound, from what I’m understanding about this stuff, you want to get an amp that can do your ideal average volume with 20 dB of additional headroom so it doesn’t clip on transients. Clipping on tube amps will be way less destructive than clipping on solid state, which will produce very obvious distortion. According to the above site (from Torq on the headphones.com forum) if your ideal average listening volume is 88.9 dB or less (which is just inside the hearing damage level), you should be good to go with 20 dB of additional headroom for clean transients.
I believe this chart is based on the published specs below. They are from the manual included with the second gen WA22, but I believe the power ratings they give in the manual are from the first gen WA22 (so it may be underestimating power a bit) - the manual appears to have been updated last in 2011... Anyway:
So, the 7236 is more powerful in the WA22 (same should be roughly true for the 5998 and 421a).
P = V^2 / R or 0.700 = V^2 / 600
solving for V —> V = 20.494
The other values in that table apply to 6080 tubes. @120 Ohm we have 13.86 V;
@300 Ohm —> 18.17 which doesn’t really tell us a ton about how it will behave with the higher power tubes, except to say that it probably will be lower than 20.494, as it appears that the voltage goes up as the impedance goes up at least to 300 Ohm, unless there is an inflection point we don’t know about between 300 and 600 Ohm, and we can’t directly compare those values here because they are with different tubes.
I actually wrote to Woo about it, and they told me they haven’t had a chance to hear a Tungsten, so they don’t know how it will do with the WA22, but they suggested I buy an Abyss Diana from them instead. This was a bit surprising and annoying, as the specs are published and I don’t think it would be that hard for them to give us an idea, especially since the creator of the Tungsten has suggested using the WA5-LE as the reference amp for demoing the Tungsten according to one of the reviews on YouTube, but I digress.
I have read that 20V is ideal for listening at fairly loud volumes, so we might be coming in a hair below that, but it should be fairly close to ideal, and with the mitigation of clipping offered by tubes, I think we will be happy with the results as long as we are using higher power tubes - 5998 / 421a / 7236 - especially if you prefer listening at sane levels.
I highly recommend checking out the thread on this over at the headphones.com forum:
https://forum.headphones.com/t/modhouse-tungsten-measurements-official-discussion/22645/72
Thanks for watching my TED Talk
