One thing about tube amps is that they are just never going to be as quiet as solid state amps regardless of price. As many of you know, I absolutely love tube amps! I own amps from DNA, Eddie Current, Glenn, Feliks and ofcourse ampsandsound, they are pretty quiet, but all of them vary based on what tubes and what is around them as well as their power and output impedance.
What I would categorize as "acceptable" noise from a tube amp would be anything that doesn't interact with the music. If you're plugging a tube amp in ( a full tube amp not a hybrid) and expecting it to be as quiet as your solid state gear that's just never going to happen, but that being said, usually the noise is quite low and especially on the low Z outs of my tube amps you have to be looking for it to find it instead of listening to music.
The other downside is that there are many factors and finicky bits about tube amps that make them pick up noise, this is part of the enjoyment for me, but I also realize a lot of people just want to plug and play which is understandable!
@ampsandsound and I tried to make the Pendant as plug and play as a tube amp could possibly be, but non-the-less some trouble shooting is needed sometimes, here's what I typically recommend.
1. Isolate the power plug away from other plugs, consider using a monster HTS strip, you can get them on ebay for like 30 bucks usually.
By the way I really recommend the monster HTS strips, for whatever reason they have worked better than many audiophile units I have tried at just getting rid of noise. It's also cheaper than most audiophile options!
2. Isolate the USB out so that you are using something that is non usb - this doesn't always cause an issue - but can.
3. Get wifi signal away from the amp, routers and or laptops using wifi can be problematic.
4. Use a 12au7 tube instead of 12ax7.
5. Try unplugging the RCA's to make sure the dac/system isn't bringing noise into the system.
As
@KPzypher mentioned though - if you can't get the amp as quiet as you want, we are always happy to check the amp out and make sure nothing is going on, worst case scenario it costs a few bucks for shipping but you'll know that your amp is in good shape! There are a ton of variables in each environment that can make a piece of gear make noise, so sometimes it's impossible for us to diagnose without checking out the amp to make sure that's not the issue.
Regardless of all this I am a big proponent of tube amps, those of us who like to mess around with different tubes, output impedance and sonic characteristics will have exponentially more fun and sonic joy than when using similar solid state gear. That's not to say I don't love solid state amps, but if I'm relaxing instead of measuring and testing I'm almost always using a tube amp!
