Where are you guys typically leaving your volume pot at for nornal listening volume on your Pendant?
Using the stock JJ 12AX7, with my Auteur on the low-z tap, I'm typically at 3-4 o'clock for solid listening volume. Atticus on the high-z is around 12-1. For the stated output specs, I'm a bit surprised I find myself dialing it up so high.
Additionally, my power tubes and rectifier get exceptionally hot and exhibit a beautiful glow, while the preamp/input tube barely emits any heat or glow. I've found on my other tube gear that the preamp tubes tend not to "glow" so much, but just wanted to see others' feedback on it!
