Chord Mojo 2 Thread ___ [product released January 31, 2022 -- starting on page 95 of thread]
May 18, 2024 at 11:57 AM Post #10,759 of 10,895
Hello, do you know if it’s possible to listen to mojo 2 poly in a car? Mine has 2 USB and 1 USB-C
No, Mojo is analog out only. You can use Mojo2's 3.5mm out to your car's 3.5mm input.
Also, most car's usb is for storage devices only, they can't accept digital audio signal.
May 18, 2024 at 12:02 PM Post #10,760 of 10,895
I have a somewhat similar question. Can I use Mojo2/Poly when driving my motorcycle? Source would be my android smartphone running qobuz using usb audio player pro (uapp). Is this a practical scenario?
May 18, 2024 at 12:03 PM Post #10,761 of 10,895
The cable must be OTG, it works connecting to the laptop, where as a previous cable wouldn't?
For phone/tablet the cable must be OTG. You can use an OTG to connect to laptop. I've not had issues using OTG cables to computers.
May 18, 2024 at 12:05 PM Post #10,762 of 10,895
Practical? Not sure. But it is doable.
May 18, 2024 at 1:22 PM Post #10,764 of 10,895
indigo I think. With the white light. Closest to 2v
May 18, 2024 at 1:26 PM Post #10,765 of 10,895
May 18, 2024 at 3:59 PM Post #10,766 of 10,895
Been enjoying the stock sound so far with the SR3. Only just decided to play with crossfeed. What's your all takes and preferred settings?
May 18, 2024 at 6:49 PM Post #10,767 of 10,895
May 18, 2024 at 9:53 PM Post #10,768 of 10,895
May 19, 2024 at 3:14 AM Post #10,769 of 10,895
Line out for Mojo 2 is 3V. But if your amp isn’t ok with a slightly higher than usual input voltage, then lower it to 2V.
I got this photo from Rob Watts post. I was sure the question was for line out.
For years I thought line out was 1v.
