Can you take some photos of the burnt part of the circuit board ??It was used just a bit so almost new since it was bought in August 2020 and he sold it to me around September or so. I could open it, but I will try to get in touch with the local dealer, as I said, i found the invoice. Not the warranty paper itself which usually is required, it should have the matching serial number.
The most upsetting is the loss of headphones, maybe I could also replace the driver, both of them actually.
Topping A90
- Thread starter bahamot
raoultrifan
Hope it's still under warranty and you can swap it for a new one. If not, then please open it up and do some pics for the eternity's sake.Be aware today my A90 fried itself and it is useless now. The smell of burned circuits... even now after one hour i sense it.
But this is not all, it also broke the headphones i was listening, fostex th909 at one moment suddenly started to hear some buzzes, clicks and snaps, now the left driver is dead, right driver sounds bad too. even the 4.4mm jack was smelling also.
So be warned. i had it with topping, too bad, i was enjoying it. Hopefully the dac is ok,didn't tested it yet but it was still up and no smell.
raoultrifan
Correct, of course, but this is why cars have breaks with failover mechanisms, like every amp should have a protection for DC on outputs. The output protection of A90 should operate when a catastrophic event appears, I wonder why it didn't kicked in this time.Any piece of electronic equipment can develop a fault and break. This is not limited to Chinese products or headphone amplifiers.
LightBlue77
If I can't get a replacement, I will open it and maybe show it to an electronic engineer so he would make sense of what happened.
MakubexGB
- Feb 27, 2005
Funny coincidence, my A90 went kaput yesterday. It developed this loud crackling and popping on all outputs at any gain and volume, whether it's connected to a source or not.
I purchased mine on October 2020 from Amazon (shipped by Amazon but the seller is Aoshida HiFi-US). I contacted the seller to see about warranty service since Topping advises to contact the seller first. I got a timely reply but they ask for some weird stuff like to take a video and send it to them. Video of what? It's an audio defect. My detailed description should be enough. We'll see how it goes.
chinese commerce require a video to show the problem, to start with. topping is chinese. if the video is not send, problem finished for them. if video is sent, step two...Funny coincidence, my A90 went kaput yesterday. It developed this loud crackling and popping on all outputs at any gain and volume, whether it's connected to a source or not.
MakubexGB
- Feb 27, 2005
Well damn, good to know. I guess I'll show them a video of the A90 just sitting there. Maybe I can catch a popping or two from my headphone in the video.chinese commerce require a video to show the problem, to start with. topping is chinese. if the video is not send, problem finished for them. if video is sent, step two...
Did the A90 blow your headphones too ??Well damn, good to know. I guess I'll show them a video of the A90 just sitting there. Maybe I can catch a popping or two from my headphone in the video.
Baten
- Sep 13, 2012
I don't think that's what he's saying, no.Did the A90 blow your headphones too ??
MakubexGB
- Feb 27, 2005
Luckily, no. I had my Ether 2 connected at the time. I immediately tested them on a different amp and they still work fine.Did the A90 blow your headphones too ??
Okay, that's good to hear, do you have static where you live due to cold dry winters ??Luckily, no. I had my Ether 2 connected at the time. I immediately tested them on a different amp and they still work fine.
MakubexGB
- Feb 27, 2005
I do. It's not extremely cold where I live but it does get cold and dry.Okay, that's good to hear, do you have static where you live due to cold dry winters ??
LightBlue77
Then I'll send them a video also, too bad it doesn't catch the smell of burned circuits, it's still persistent after 2 days since the incident.
Hey there, could you maybe also provide us with the Serial Number of your Amp?Funny coincidence, my A90 went kaput yesterday. It developed this loud crackling and popping on all outputs at any gain and volume, whether it's connected to a source or not.
MakubexGB
- Feb 27, 2005
