I can't help you since I don't have that issue that you allege in your DAP.(...) has anyone else reported similar issues ? What might it be ? Could you make original sw available to reinstall ?
Cayin N3Ultra: an Entry-level Portable DAP that Delivers a Complete Vacuum Tube Audio Experience
- Thread starter Andykong
bigbass9000
Any plans on adding grouping by album artist? This is the one feature I'm missing right now, most other music apps and players can do this no problem.
The Announcement of N3Ultra Firmware v1.1
New Functions and System Optimization
Firmware ULR: https://en.cayin.cn/drive/9/18/633.html
- Move “Scan Music” to the “Music Settings” menu, and add a scanning setting to enable user customization of the scanning process.
- Repair the problem of abnormal termination of the Cayin Music App when clicking the multiple selection button in the upper right corner of various music listing pages;
- Repair the problem that some UI descriptions/icons are not displayed properly in the EQ/PEQ interface
- Add shutdown memory function for sample rate indicator setting, DSD gain compensation setting, and channel balance setting;
- Modify the default save location of EQ/PEQ to local storage;
- Modify the selected User Interface;
- Other optimization and bugs fixed
Firmware Update
Cayin will release firmware updates to enhance and optimize N3Ultra as deemed required. Users can update the firmware through local update. To manually download the firmware, please visit the SUPPORT center of our official website.
A Kind Reminder to N3Ultra Firmware Upgrade
- Each version of firmware might contain minor differences, consumer please decide on your own accord whether you need to update the firmware of your N3Ultra Digital Audio Player.
- Under normal circumstances, firmware upgrades will not cause any damage to user information, but Cayin cannot exclude the possibility of upgrade failure due to malfunction or any other reason. For these reasons, we strongly suggest you remove all storage devices inserted into the DAP before you perform the firmware upgrade.
- The N3Ultra firmware cannot be used in other products, and the firmware from other products cannot be used in N3Ultra
Attention
- Please make sure the N3Ultra has not less than 30% battery power, otherwise please charge up the player before you proceed to a firmware update.
- Please make sure your TF card has more than 2GB of storage before the firmware update.
Firmware Update Procedures
- Download the latest firmware update package from the Support Center of Cayin website, please select “Personal Audio” on this page.
- You should receive a compressed file (cayin_N3Ultra_xxx_xxxxxxx_8.1_user_update.zip) for the N3Ultra firmware update. DO NOT decompress the zip file.
- Copy the firmware file into the root directory of your TF card, and insert the TF card into N3Ultra before you proceed to the next step.
- Select "System Settings" on the main menu, at the Setting menu page select “System” and then select "FOTA* Updates” to enter the firmware update interface;
- Select “Local updates” in the System Update screen.
- Proceed to the root directory of your TF card, then select the firmware file.
- The system will remind you that the device will be restarted during the firmware update, select “OK” in the confirmation window, and the system will start the firmware upgrade process;
- Do not operate the device during a firmware update. After the upgrade is complete, the system will reboot automatically and you can use the DAP when the device resumes from reboot.
- Please delete the firmware file from the TF card after you have completed the firmware update process
* FOTA stands for Firmware Over-The-Air
What preferences do you have about the PCM Filter?
It’s reporting build nr 1.10… I had shut it off for an hour or 2 and just turned it on and I hit the button to turn off the screen twice and it turned it on almost immediately both times… will try factory resetI can't help you since I don't have that issue that you allege in your DAP.
Yes sorry, firmware v1.10It’s reporting build nr 1.10…
fish1050
It might be that it only supports standard jpeg and not progressive jpeg like my Sony A55 so size wouldn't be the issue.Album art thumbnails continue to be problematic. I went through all my albums and tracks to resize the embedded art to 500x500 and on some screens there is a thumbnail, on other screens the same album art thumbnail does not show at all. I guess instead of rescanning, maybe it's better to wipe the database and scan from scratch? Not even sure if that will resolve anything.
All jpg. I did have a problem a couple years ago with album art due to dowloading some progressive jpg images and embedded them in some of my albums. After converting all progressive jpg to normal jpg, covers were working again. From then on I make sure to have only normal jpg cover files.Is all the album art in the same format ie: .jpg or .png?
@Andykong after the update the screen turns on randomly. It’s done it a couple of times now during playback and even without anything playing and no headphone in. I took headphones out paused playback turned the screen off set it down and timed it to around 3.5 minutes until it turned the screen on by itself. Then shut it down, turned it on and turned off the screen without playing any music or changing anything, set it down and 12 seconds later it turned on by itself. hardware wise nothing seems loose and it never did this before the sw update … has anyone else reported similar issues ? What might it be ? Could you make original sw available to reinstall ?
The firmware v1.1 is unlikely the root of your problem because other users are not having the same problem after they upgraded their firmware, maybe the firmware update is not completed properly, or maybe there is a software glitch at the end of the firmware upgrade. Please reinstall the firmware package by going through the manual upgrade process again. Hopefully, this will solve the unstable software operation that you are facing.
Stay updated on Cayin at their sponsor profile on Head-Fi.
The Album art non-display problem is consistent across all user interfaces? Can the album art be displayed during normal playback?
Can you upload the albums that can't be displayed properly and let me download and test them in my N3Ultra? I don't need the full album, only two songs per album (I assume the embedded album art is identical across all titles in the same album), and 2-3 albums to conduct the testings. Drop me the link (Google Drive is preferred) through PM and I'll follow up with our engineers.
I followed all the steps exactly as they are written and the software update completed successfully then the device restarted at the end and was working fine. I also removed the firmware file from the tf card after the update as instructed and it was working fine before I noticed the screen turning on by itself. I did a factory reset and it’s been working fine for around 9 hours so that seems to have fixed the issue. Will keep an eye on it and see if it happens again, hopefully not. ThanksThe firmware v1.1 is unlikely the root of your problem because other users are not having the same problem after they upgraded their firmware, maybe the firmware update is not completed properly, or maybe there is a software glitch at the end of the firmware upgrade. Please reinstall the firmware package by going through the manual upgrade process again. Hopefully, this will solve the unstable software operation that you are facing.
Thank you for following up on the album art problems. Since there is no way to only delete the music database, I did an "Erase all data (factory reset)" of the player which cleared everything and start from scratch. Afterwards I scanned my Music folder on the microSD card and all album art is now displayed properly.The Album art non-display problem is consistent across all user interfaces? Can the album art be displayed during normal playback?
Before upgrading from FW1.00, even after I had resized and double check all album art is 500x500, then perform a music scan the art for some albums was not displaying properly in 'Album' view. In 'Artist' view, the top layer would always display an album art next to the artist name, but when I select an artist, some of the album art for 1 or 2 albums were missing. Anyway, whether in Album view or Artist view, if I selected an album to play that did not show any album thumbnail, then the album art would be okay on the playback screen.
After I upgraded to FW1.10, I was expecting the album art to display properly, but it was the same issue as described above even if I rescan my Music folder. That is when I decided to just erase all data (Factory reset) and perform a new scan and afterwards all album art is displaying properly now.
If you want to erase the music database, you can insert a TF card with no music files on it and perform a music scan, this will create a null music library to replace your previous music library. I haven't tried this with N3Ultra but that's how it work with other Cayin DAP.Thank you for following up on the album art problems. Since there is no way to only delete the music database, I did an "Erase all data (factory reset)" of the player which cleared everything and start from scratch. Afterwards I scanned my Music folder on the microSD card and all album art is now displayed properly.
Thanks for that work around, but wouldn't it be a more elegant solution to have a Delete DB button in the user interface or settings?If you want to erase the music database, you can insert a TF card with no music files on it and perform a music scan, this will create a null music library to replace your previous music library. I haven't tried this with N3Ultra but that's how it work with other Cayin DAP.
Ymzable
- Jan 9, 2013
You need to add one custom EQ under the regular EQ settings, and then you can save your custom settings in PEQ.I'm sorry, what is the work around here? I won't buy it if I can't save multiple EQ presets.
They might have already fixed this in the 1.10 firmware though.
Yes, the default setting of both EQ and PEQ are changed to local storage in v1.1 firmware.You need to add one custom EQ under the regular EQ settings, and then you can save your custom settings in PEQ.
Total: 17 (members: 7, guests: 10)
