iFi audio NEO iDSD - The Performance Edition is here! (INFO: Post 837, Page 56)
- Thread starter iFi audio
Baten
- Sep 13, 2012
Honestly looks extremely similar to previous Neo, Diablo, ... internals.
I guess it's mostly better XMOS/BT chips
Im a little annoyed they just dont make a “desktop” version of diablo. All those gimmicks I dont want them.Honestly looks extremely similar to previous Neo, Diablo, ... internals.
reynaldohm
Everyone talks about one chip, but I think there are two. Both in the old version and in this new one.How many BB chips is inside? @iFi audio
The problem is that you don't have a view of the bottom of the board.
See that in the iFi Neo Stream there is another chip at the bottom of the board.
Mr BubbaHyde
Sponsor: iFi audio
Hi Folks!
Let us move the discussion of the New NEO iDSD 2 here if we can!
Thanks
https://www.head-fi.org/threads/int...rlds-first-lossless-bluetooth-dac-amp.969836/
Cheers!!
Thanks
Cheers!!
Stay updated on iFi audio at their sponsor profile on Head-Fi.
That chip that looks like burr brown is the controller chip for the clocksEveryone talks about one chip, but I think there are two. Both in the old version and in this new one.
mformoriarty
What is the difference between the original neo idsd vs the newer performance model?
Nothing. Just included usb and rca filter. Device absolutely the sameWhat is the difference between the original neo idsd vs the newer performance model?
- Mar 20, 2013
Take a look here for differences between models, there are a few things that have changed ...Nothing. Just included usb and rca filter. Device absolutely the same
https://ifi-audio.com/products/neo-idsd-2/
Cheers!!
Hi. Maybe a question about "performance edition" no?)Take a look here for differences between models, there are a few things that have changed ...
Cheers!!
- Mar 20, 2013
My bad it's been a long day!!Hi. Maybe a question about "performance edition" no?)
Apologies!
Cheers!!
mformoriarty
Aside from the amplifier options and bluetooth, is the DAC chip set the same on the new idsd 2 vs the one on the original? I have the original one, mostly use it as a DAC but would consider trying the new one if it is worth the upgrade in that department.Take a look here for differences between models, there are a few things that have changed ...
Cheers!!
- Mar 20, 2013
I will see what I can find out for you there and report back!Aside from the amplifier options and bluetooth, is the DAC chip set the same on the new idsd 2 vs the one on the original? I have the original one, mostly use it as a DAC but would consider trying the new one if it is worth the upgrade in that department.
Cheers!!
- Mar 20, 2013
They are the same chip sir, hope this helps you out!Aside from the amplifier options and bluetooth, is the DAC chip set the same on the new idsd 2 vs the one on the original? I have the original one, mostly use it as a DAC but would consider trying the new one if it is worth the upgrade in that department.
Cheers!!
