Pads on LCD2s are hand-made, resulting in dysymetries and irregularities, but :
Classic : the foam inside the pad was hand cutted
Rev1 : the foam is industrially cutted for more precision and consistence, couture is still handmade
Tyll posted a pic comparing the two pads, despite the "classic" pads looking thinner, in fact they make the same angle
Then there is two groups of people, the ones who believe they noticed a sound change between their old version and the rev1 and the ones who don't...I cannot say exactly the pourcentages but i believe the latter group is more ponderous
If the pads don't make a change (since the angle is the same) there is no point making a distinction classic/rev1.
To add a little spice, the grill changed too, and that could have affect the sound (try covering one grill with your hand and you'll notice dramatical sonic channge)
On REV1/REV2 : after reading all the posts, i decided to keep my rev1 :
creamy vocals oh yeah, they are 'in my head' it's
involving
-i discovered i really hate brightness, i tried many times to eq the 2s adding a little bit high frequencies, it always translated in a more fatiguing sound. The ability for a headphone to be
non-fatiguing is something i under-estimated before. I can listen rev1 for hours, even cranking up the volume, without having those ear-piercing highs that i hate so much. I understand rev2 does not add brightness for some, but i really don't wanna take the risk since i already find rev1 "perfect" for me.
-I'm not so fond of details as i thought i was. Most of the records i own have a lot of flaws (and i believe that is like >95% recordings have really significant artefacts/popping sounds,etc...) and i'm not sure i want to take all the defects of the record in my face, being able to listen only to the best audiophile quality recordings...
-last night for the first time i cried listening to my headphones...not because of the music, but because of the sound, the way it was portrayed by the LCD2...i think i turned an audiophile last night...
-maybe the rev1 has become somewhat 'unique' in the way they portray the sound (especially on vocals)
-remember i'm not saying that rev2 does not present the qualities i stated, i just don't wanna take the risk of losing them
On comfort : yes the LCD2 is heavy, but it is the most comfortable headphones i own (DT880, K701, HD650). With every other headphones, i'll find that they'll hurt somewhere around my head in less than an hour whereas i can wear the LCD2 as long as i want.
