In fact the world of audio signals is divided in three main groups:Line level refers to low level signals like the rca analog output of a dac, 1-5v, 2v rca 5v xlr, headphone amps and preamps, while not quite high level(high level being an amplified signal, think speaker wire) are higher at 10v to 20v.
Low Level 0.001V to 0.3V, low energy:
microphones, turn table pickups etc., all kind of low voltage and low energy signals, often before being electronically amplified.
Line level, Voltage 0.3V - 20V, low energy, typically 2V:
intercontacts between different electronic audio devices, outputs from cd-players, cassette-decks and tape machines, interconnect between preamplifier and power amplifier, interconnects in recording studios, even the analog telephone line counts into that and gave the signal its name.
Power level, Voltage 0.1V to 100V, energy/power 0.001W to multiples of 10,000W:
all kind of signals originating from power amplifiers, intended to drive some kind of speakers or headphones.
This one has the widest variety of voltage and energy transmission, because it's an enormous difference if you want to drive sensitive InEars, or a big PA system in a show.
For a sensitive InEar 1/1000 of a Watt might be sufficient for earhurting levels, on a PA system for a bigger audience 100,000W may be necessary to serve the same purpose.
As can be seen, there is quite some overlap with the line level voltages, and such power amplifiers can be used as line drivers too, as long as the receivers maximum healthy voltage is not exceeded.
The problem might be, that power amplifiers, in contrary to most dedicated line drivers, are capable of supplying sufficient energy to literally toast electronic parts.
Mobius Aux input works with line level, and it's only the voltage that counts. It does not draw significant amounts of energy out of the source (it has a high input impedance).
According to my measurements Mobius can handle up to 1.8V without distortion, and and this is what's needed to drive it to full scale sound level.
If this level is not exceeded, nothing can break, no matter where the signal originates from.
This is about the output voltage that most home HiFi cd-players send.
There is no analog variable gain circuit built into Mobius, so levels far below this will not drive Mobius sufficiently.
