- Oct 18, 2016
Cool thx will look them up though I’m in U.K.
Me too mate. I've ordered from them 4 times now without issue.
Will do - thank you. They look very niceIf you are looking for premium cables talk to Sebastian at Viking Weave, he's in the UK.
He goes to great lengths to try make exactly what you are looking for.Will do - thank you. They look very nice
GorgeousI thought I would drop in this Nighthawk porn pic.
I recently dug them out for a listen. I marvel at their design and yes I like their sound.
Balanced connection into Woo WA22 or SPL Phonitor Xe.
That’s great to know. Important to look after people like that.He goes to great lengths to try make exactly what you are looking for.
Low gain all the way; specs for that amp say 6W RMS per channel @32 Ohms for the single-ended out.Can anyone recommend gain setting for Schiit Ragnarok 2 using single ended output and 1/4” cable with Nighthawk please?
Yeah lot of power. Have to turn the pot up a fair bit though.Low gain all the way; specs for that amp say 6W RMS per channel @32 Ohms for the single-ended out.
I don't think there is, it'd be rare to find them. You could try eBay. I was half tempted to buy another paid of headphones as they're easier to find than just the pads. Though you can just use aftermarket pads. I believe in the forums somewhere there were people talking about using a hole punch on some other pads and using the same rings or possibly even 3d printed replacement rings. So I know people replace the pads.Assume there's no way of getting any more hybrid pads now...?
Thanks for confirming - thought as much. Got a 2nd hand pair of OG Nighthawks on the way (started regretted selling my Nightowls) which will have the hybrids but ideally I'd have a spare set to hand. Could grab some of the leather pads as those still seem to be available...I don't think there is, it'd be rare to find them. You could try eBay. I was half tempted to buy another paid of headphones as they're easier to find than just the pads. Though you can just use aftermarket pads. I believe in the forums somewhere there were people talking about using a hole punch on some other pads and using the same rings or possibly even 3d printed replacement rings. So I know people replace the pads.
