Hmm, I held it for 10secs on each side. I will try more later.
Not on each side ie left and right, it has to be 10 seconds at each bend point. Jusst follow this hyper detailed workflow.
1. Pull left earcup to fully extend metal retention arm.
2. Pull right earcup to fully extend metal retention arm.
3. Place thumbs on left metal retention arm, with the thumbs meeting in the center of the fully extended metal arm. Bend outwards and hold for 10 seconds.
4. Place thumbs on right metal retention arm, with the thumbs meeting in the center of the fully extended metal arm. Bend outwards and hold for 10 seconds.
5. Place thumbs on left metal retention arm, with one thumb on the plastic gimbal (that kitschy marble blue fork that holds the earcup) and the other thumb positioned in such a way that the center ie the bend point will be about 5mm above the gimbal. Bend outward and hold for 10seconds.
6. Place thumbs on right metal retention arm, with one thumb on the plastic gimbal and the other thumb positioned in such a way that the center ie the bend point will be about 5mm above the gimbal. Bend outward and hold for 10seconds.
7. Place thumbs on left metal retention arm, with the thumbs meeting in the center of the fully extended metal arm. Bend outwards and hold for 10 seconds.
8. Place thumbs on right metal retention arm, with the thumbs meeting in the center of the fully extended metal arm. Bend outwards and hold for 10 seconds.
9. Place thumbs on left metal retention arm, with one thumb on the plastic gimbal and the other thumb positioned in such a way that the center ie the bend point will be about 5mm above the gimbal. Bend outward and hold for 10seconds.
10. Place thumbs on right metal retention arm, with one thumb on the plastic gimbal and the other thumb positioned in such a way that the center ie the bend point will be about 5mm above the gimbal. Bend outward and hold for 10seconds.
11. Place thumbs on left metal retention arm, with the thumbs meeting in the center of the fully extended metal arm. Bend outwards and hold for 10 seconds.
12. Place thumbs on right metal retention arm, with the thumbs meeting in the center of the fully extended metal arm. Bend outwards and hold for 10 seconds.
13. Place thumbs on left metal retention arm, with one thumb on the plastic gimbal and the other thumb positioned in such a way that the center ie the bend point will be about 5mm above the gimbal. Bend outward and hold for 10seconds.
14. Place thumbs on right metal retention arm, with one thumb on the plastic gimbal and the other thumb positioned in such a way that the center ie the bend point will be about 5mm above the gimbal. Bend outward and hold for 10seconds.
15. Place thumbs on left metal retention arm, with the thumbs meeting in the center of the fully extended metal arm. Bend outwards and hold for 10 seconds.
16. Place thumbs on right metal retention arm, with the thumbs meeting in the center of the fully extended metal arm. Bend outwards and hold for 10 seconds.
17. Place thumbs on left metal retention arm, with one thumb on the plastic gimbal and the other thumb positioned in such a way that the center ie the bend point will be about 5mm above the gimbal. Bend outward and hold for 10seconds.
18. Place thumbs on right metal retention arm, with one thumb on the plastic gimbal and the other thumb positioned in such a way that the center ie the bend point will be about 5mm above the gimbal. Bend outward and hold for 10seconds.
19. Place thumbs on left metal retention arm, with the thumbs meeting in the center of the fully extended metal arm. Bend outwards and hold for 10 seconds.
20. Place thumbs on right metal retention arm, with the thumbs meeting in the center of the fully extended metal arm. Bend outwards and hold for 10 seconds.
21. Place thumbs on left metal retention arm, with one thumb on the plastic gimbal and the other thumb positioned in such a way that the center ie the bend point will be about 5mm above the gimbal. Bend outward and hold for 10seconds.
22. Place thumbs on right metal retention arm, with one thumb on the plastic gimbal and the other thumb positioned in such a way that the center ie the bend point will be about 5mm above the gimbal. Bend outward and hold for 10seconds.
23. Place thumbs on left metal retention arm, with the thumbs meeting in the center of the fully extended metal arm. Bend outwards and hold for 10 seconds.
24. Place thumbs on right metal retention arm, with the thumbs meeting in the center of the fully extended metal arm. Bend outwards and hold for 10 seconds.
25. Place thumbs on left metal retention arm, with one thumb on the plastic gimbal and the other thumb positioned in such a way that the center ie the bend point will be about 5mm above the gimbal. Bend outward and hold for 10seconds.
26. Place thumbs on right metal retention arm, with one thumb on the plastic gimbal and the other thumb positioned in such a way that the center ie the bend point will be about 5mm above the gimbal. Bend outward and hold for 10seconds.
27. Place thumbs on left metal retention arm, with the thumbs meeting in the center of the fully extended metal arm. Bend outwards and hold for 10 seconds.
28. Place thumbs on right metal retention arm, with the thumbs meeting in the center of the fully extended metal arm. Bend outwards and hold for 10 seconds.
29. Place thumbs on left metal retention arm, with one thumb on the plastic gimbal and the other thumb positioned in such a way that the center ie the bend point will be about 5mm above the gimbal. Bend outward and hold for 10seconds.
30. Place thumbs on right metal retention arm, with one thumb on the plastic gimbal and the other thumb positioned in such a way that the center ie the bend point will be about 5mm above the gimbal. Bend outward and hold for 10seconds.
31. Place thumbs on left metal retention arm, with the thumbs meeting in the center of the fully extended metal arm. Bend outwards and hold for 10 seconds.
32. Place thumbs on right metal retention arm, with the thumbs meeting in the center of the fully extended metal arm. Bend outwards and hold for 10 seconds.
33. Place thumbs on left metal retention arm, with one thumb on the plastic gimbal and the other thumb positioned in such a way that the center ie the bend point will be about 5mm above the gimbal. Bend outward and hold for 10seconds.
34. Place thumbs on right metal retention arm, with one thumb on the plastic gimbal and the other thumb positioned in such a way that the center ie the bend point will be about 5mm above the gimbal. Bend outward and hold for 10seconds.
35. Place thumbs on left metal retention arm, with the thumbs meeting in the center of the fully extended metal arm. Bend outwards and hold for 10 seconds.
36. Place thumbs on right metal retention arm, with the thumbs meeting in the center of the fully extended metal arm. Bend outwards and hold for 10 seconds.
37. Place thumbs on left metal retention arm, with one thumb on the plastic gimbal and the other thumb positioned in such a way that the center ie the bend point will be about 5mm above the gimbal. Bend outward and hold for 10seconds.
38. Place thumbs on right metal retention arm, with one thumb on the plastic gimbal and the other thumb positioned in such a way that the center ie the bend point will be about 5mm above the gimbal. Bend outward and hold for 10seconds.
39. Place thumbs on left metal retention arm, with the thumbs meeting in the center of the fully extended metal arm. Bend outwards and hold for 10 seconds.
40. Place thumbs on right metal retention arm, with the thumbs meeting in the center of the fully extended metal arm. Bend outwards and hold for 10 seconds.
41. Place thumbs on left metal retention arm, with one thumb on the plastic gimbal and the other thumb positioned in such a way that the center ie the bend point will be about 5mm above the gimbal. Bend outward and hold for 10seconds.
42. Place thumbs on right metal retention arm, with one thumb on the plastic gimbal and the other thumb positioned in such a way that the center ie the bend point will be about 5mm above the gimbal. Bend outward and hold for 10seconds.
43. Hold left earcup. Push back into the headband to shorten the extension of the metal arm to your preferred setting as before.
44. Hold right earcup. Push back into the headband to shorten the extension of the metal arm to your preferred setting as before.
45. Do a test fit. Is it good? No? Try adjusting how far out the metal arms are extended - shorter and longer. Did either work? If not, continue.
46. Pull left earcup to fully extend metal retention arm.
47. Pull right earcup to fully extend metal retention arm.
48. Place thumbs on left metal retention arm, with the thumbs meeting in the center of the fully extended metal arm. Bend outwards and hold for 10 seconds.
49. Place thumbs on right metal retention arm, with the thumbs meeting in the center of the fully extended metal arm. Bend outwards and hold for 10 seconds.
50. Place thumbs on left metal retention arm, with one thumb on the plastic gimbal and the other thumb positioned in such a way that the center ie the bend point will be about 5mm above the gimbal. Bend outward and hold for 10seconds.
51. Place thumbs on right metal retention arm, with one thumb on the plastic gimbal and the other thumb positioned in such a way that the center ie the bend point will be about 5mm above the gimbal. Bend outward and hold for 10seconds.
52. Place thumbs on left metal retention arm, with the thumbs meeting in the center of the fully extended metal arm. Bend outwards and hold for 10 seconds.
53. Place thumbs on right metal retention arm, with the thumbs meeting in the center of the fully extended metal arm. Bend outwards and hold for 10 seconds.
54. Place thumbs on left metal retention arm, with one thumb on the plastic gimbal and the other thumb positioned in such a way that the center ie the bend point will be about 5mm above the gimbal. Bend outward and hold for 10seconds.
55. Place thumbs on right metal retention arm, with one thumb on the plastic gimbal and the other thumb positioned in such a way that the center ie the bend point will be about 5mm above the gimbal. Bend outward and hold for 10seconds.
56. Place thumbs on left metal retention arm, with the thumbs meeting in the center of the fully extended metal arm. Bend outwards and hold for 10 seconds.
57. Place thumbs on right metal retention arm, with the thumbs meeting in the center of the fully extended metal arm. Bend outwards and hold for 10 seconds.
58. Place thumbs on left metal retention arm, with one thumb on the plastic gimbal and the other thumb positioned in such a way that the center ie the bend point will be about 5mm above the gimbal. Bend outward and hold for 10seconds.
59. Place thumbs on right metal retention arm, with one thumb on the plastic gimbal and the other thumb positioned in such a way that the center ie the bend point will be about 5mm above the gimbal. Bend outward and hold for 10seconds.
60. Place thumbs on left metal retention arm, with the thumbs meeting in the center of the fully extended metal arm. Bend outwards and hold for 10 seconds.
61. Place thumbs on right metal retention arm, with the thumbs meeting in the center of the fully extended metal arm. Bend outwards and hold for 10 seconds.
62. Place thumbs on left metal retention arm, with one thumb on the plastic gimbal and the other thumb positioned in such a way that the center ie the bend point will be about 5mm above the gimbal. Bend outward and hold for 10seconds.
63. Place thumbs on right metal retention arm, with one thumb on the plastic gimbal and the other thumb positioned in such a way that the center ie the bend point will be about 5mm above the gimbal. Bend outward and hold for 10seconds.
64. Place thumbs on left metal retention arm, with the thumbs meeting in the center of the fully extended metal arm. Bend outwards and hold for 10 seconds.
65. Place thumbs on right metal retention arm, with the thumbs meeting in the center of the fully extended metal arm. Bend outwards and hold for 10 seconds.
66. Place thumbs on left metal retention arm, with one thumb on the plastic gimbal and the other thumb positioned in such a way that the center ie the bend point will be about 5mm above the gimbal. Bend outward and hold for 10seconds.
67. Place thumbs on right metal retention arm, with one thumb on the plastic gimbal and the other thumb positioned in such a way that the center ie the bend point will be about 5mm above the gimbal. Bend outward and hold for 10seconds.
68. Place thumbs on left metal retention arm, with the thumbs meeting in the center of the fully extended metal arm. Bend outwards and hold for 10 seconds.
69. Place thumbs on right metal retention arm, with the thumbs meeting in the center of the fully extended metal arm. Bend outwards and hold for 10 seconds.
70. Place thumbs on left metal retention arm, with one thumb on the plastic gimbal and the other thumb positioned in such a way that the center ie the bend point will be about 5mm above the gimbal. Bend outward and hold for 10seconds.
71. Place thumbs on right metal retention arm, with one thumb on the plastic gimbal and the other thumb positioned in such a way that the center ie the bend point will be about 5mm above the gimbal. Bend outward and hold for 10seconds.
72. Place thumbs on left metal retention arm, with the thumbs meeting in the center of the fully extended metal arm. Bend outwards and hold for 10 seconds.
73. Place thumbs on right metal retention arm, with the thumbs meeting in the center of the fully extended metal arm. Bend outwards and hold for 10 seconds.
74. Place thumbs on left metal retention arm, with one thumb on the plastic gimbal and the other thumb positioned in such a way that the center ie the bend point will be about 5mm above the gimbal. Bend outward and hold for 10seconds.
75. Place thumbs on right metal retention arm, with one thumb on the plastic gimbal and the other thumb positioned in such a way that the center ie the bend point will be about 5mm above the gimbal. Bend outward and hold for 10seconds.
76. Place thumbs on left metal retention arm, with the thumbs meeting in the center of the fully extended metal arm. Bend outwards and hold for 10 seconds.
77. Place thumbs on right metal retention arm, with the thumbs meeting in the center of the fully extended metal arm. Bend outwards and hold for 10 seconds.
78. Place thumbs on left metal retention arm, with one thumb on the plastic gimbal and the other thumb positioned in such a way that the center ie the bend point will be about 5mm above the gimbal. Bend outward and hold for 10seconds.
79. Place thumbs on right metal retention arm, with one thumb on the plastic gimbal and the other thumb positioned in such a way that the center ie the bend point will be about 5mm above the gimbal. Bend outward and hold for 10seconds.
80. Place thumbs on left metal retention arm, with the thumbs meeting in the center of the fully extended metal arm. Bend outwards and hold for 10 seconds.
81. Place thumbs on right metal retention arm, with the thumbs meeting in the center of the fully extended metal arm. Bend outwards and hold for 10 seconds.
82. Place thumbs on left metal retention arm, with one thumb on the plastic gimbal and the other thumb positioned in such a way that the center ie the bend point will be about 5mm above the gimbal. Bend outward and hold for 10seconds.
83. Place thumbs on right metal retention arm, with one thumb on the plastic gimbal and the other thumb positioned in such a way that the center ie the bend point will be about 5mm above the gimbal. Bend outward and hold for 10seconds.
84. Place thumbs on left metal retention arm, with the thumbs meeting in the center of the fully extended metal arm. Bend outwards and hold for 10 seconds.
85. Place thumbs on right metal retention arm, with the thumbs meeting in the center of the fully extended metal arm. Bend outwards and hold for 10 seconds.
86. Place thumbs on left metal retention arm, with one thumb on the plastic gimbal and the other thumb positioned in such a way that the center ie the bend point will be about 5mm above the gimbal. Bend outward and hold for 10seconds.
87. Place thumbs on right metal retention arm, with one thumb on the plastic gimbal and the other thumb positioned in such a way that the center ie the bend point will be about 5mm above the gimbal. Bend outward and hold for 10seconds.
88. Place thumbs on left metal retention arm, with the thumbs meeting in the center of the fully extended metal arm. Bend outwards and hold for 10 seconds.
89. Place thumbs on right metal retention arm, with the thumbs meeting in the center of the fully extended metal arm. Bend outwards and hold for 10 seconds.
90. Place thumbs on left metal retention arm, with one thumb on the plastic gimbal and the other thumb positioned in such a way that the center ie the bend point will be about 5mm above the gimbal. Bend outward and hold for 10seconds.
91. Place thumbs on right metal retention arm, with one thumb on the plastic gimbal and the other thumb positioned in such a way that the center ie the bend point will be about 5mm above the gimbal. Bend outward and hold for 10seconds.
91. Place thumbs on left metal retention arm, with the thumbs meeting in the center of the fully extended metal arm. Bend outwards and hold for 10 seconds.
92. Place thumbs on right metal retention arm, with the thumbs meeting in the center of the fully extended metal arm. Bend outwards and hold for 10 seconds.
93. Place thumbs on left metal retention arm, with one thumb on the plastic gimbal and the other thumb positioned in such a way that the center ie the bend point will be about 5mm above the gimbal. Bend outward and hold for 10seconds.
94. Place thumbs on right metal retention arm, with one thumb on the plastic gimbal and the other thumb positioned in such a way that the center ie the bend point will be about 5mm above the gimbal. Bend outward and hold for 10seconds.
95. Place thumbs on left metal retention arm, with the thumbs meeting in the center of the fully extended metal arm. Bend outwards and hold for 10 seconds.
96. Place thumbs on right metal retention arm, with the thumbs meeting in the center of the fully extended metal arm. Bend outwards and hold for 10 seconds.
97. Place thumbs on left metal retention arm, with one thumb on the plastic gimbal and the other thumb positioned in such a way that the center ie the bend point will be about 5mm above the gimbal. Bend outward and hold for 10seconds.
98. Place thumbs on right metal retention arm, with one thumb on the plastic gimbal and the other thumb positioned in such a way that the center ie the bend point will be about 5mm above the gimbal. Bend outward and hold for 10seconds.
99. Place thumbs on left metal retention arm, with the thumbs meeting in the center of the fully extended metal arm. Bend outwards and hold for 10 seconds.
101. Place thumbs on right metal retention arm, with the thumbs meeting in the center of the fully extended metal arm. Bend outwards and hold for 10 seconds.
102. Place thumbs on left metal retention arm, with one thumb on the plastic gimbal and the other thumb positioned in such a way that the center ie the bend point will be about 5mm above the gimbal. Bend outward and hold for 10seconds.
103. Place thumbs on right metal retention arm, with one thumb on the plastic gimbal and the other thumb positioned in such a way that the center ie the bend point will be about 5mm above the gimbal. Bend outward and hold for 10seconds.
104. Do a test fit. Is it good? No? Try adjusting how far out the metal arms are extended - shorter and longer. Did either work? If not, continue.
105. Place thumbs on left metal retention arm, with the thumbs meeting in the center of the fully extended metal arm. Bend outwards and hold for 10 seconds.
106. Place thumbs on right metal retention arm, with the thumbs meeting in the center of the fully extended metal arm. Bend outwards and hold for 10 seconds.
107. Place thumbs on left metal retention arm, with one thumb on the plastic gimbal and the other thumb positioned in such a way that the center ie the bend point will be about 5mm above the gimbal. Bend outward and hold for 10seconds.
108. Place thumbs on right metal retention arm, with one thumb on the plastic gimbal and the other thumb positioned in such a way that the center ie the bend point will be about 5mm above the gimbal. Bend outward and hold for 10seconds.
109. Place thumbs on left metal retention arm, with the thumbs meeting in the center of the fully extended metal arm. Bend outwards and hold for 10 seconds.
110. Place thumbs on right metal retention arm, with the thumbs meeting in the center of the fully extended metal arm. Bend outwards and hold for 10 seconds.
111. Place thumbs on left metal retention arm, with one thumb on the plastic gimbal and the other thumb positioned in such a way that the center ie the bend point will be about 5mm above the gimbal. Bend outward and hold for 10seconds.
112. Place thumbs on right metal retention arm, with one thumb on the plastic gimbal and the other thumb positioned in such a way that the center ie the bend point will be about 5mm above the gimbal. Bend outward and hold for 10seconds.
113. Place thumbs on left metal retention arm, with the thumbs meeting in the center of the fully extended metal arm. Bend outwards and hold for 10 seconds.
114. Place thumbs on right metal retention arm, with the thumbs meeting in the center of the fully extended metal arm. Bend outwards and hold for 10 seconds.
115. Place thumbs on left metal retention arm, with one thumb on the plastic gimbal and the other thumb positioned in such a way that the center ie the bend point will be about 5mm above the gimbal. Bend outward and hold for 10seconds.
116. Place thumbs on right metal retention arm, with one thumb on the plastic gimbal and the other thumb positioned in such a way that the center ie the bend point will be about 5mm above the gimbal. Bend outward and hold for 10seconds.
117. Place thumbs on left metal retention arm, with the thumbs meeting in the center of the fully extended metal arm. Bend outwards and hold for 10 seconds.
118. Place thumbs on right metal retention arm, with the thumbs meeting in the center of the fully extended metal arm. Bend outwards and hold for 10 seconds.
119. Place thumbs on left metal retention arm, with one thumb on the plastic gimbal and the other thumb positioned in such a way that the center ie the bend point will be about 5mm above the gimbal. Bend outward and hold for 10seconds.
120. Place thumbs on right metal retention arm, with one thumb on the plastic gimbal and the other thumb positioned in such a way that the center ie the bend point will be about 5mm above the gimbal. Bend outward and hold for 10seconds.
121. Place thumbs on left metal retention arm, with the thumbs meeting in the center of the fully extended metal arm. Bend outwards and hold for 10 seconds.
122. Place thumbs on right metal retention arm, with the thumbs meeting in the center of the fully extended metal arm. Bend outwards and hold for 10 seconds.
123. Place thumbs on left metal retention arm, with one thumb on the plastic gimbal and the other thumb positioned in such a way that the center ie the bend point will be about 5mm above the gimbal. Bend outward and hold for 10seconds.
124. Place thumbs on right metal retention arm, with one thumb on the plastic gimbal and the other thumb positioned in such a way that the center ie the bend point will be about 5mm above the gimbal. Bend outward and hold for 10seconds.
125. Place thumbs on left metal retention arm, with the thumbs meeting in the center of the fully extended metal arm. Bend outwards and hold for 10 seconds.
126. Place thumbs on right metal retention arm, with the thumbs meeting in the center of the fully extended metal arm. Bend outwards and hold for 10 seconds.
127. Place thumbs on left metal retention arm, with one thumb on the plastic gimbal and the other thumb positioned in such a way that the center ie the bend point will be about 5mm above the gimbal. Bend outward and hold for 10seconds.
128. Place thumbs on right metal retention arm, with one thumb on the plastic gimbal and the other thumb positioned in such a way that the center ie the bend point will be about 5mm above the gimbal. Bend outward and hold for 10seconds.
129. Place thumbs on left metal retention arm, with the thumbs meeting in the center of the fully extended metal arm. Bend outwards and hold for 10 seconds.
130. Place thumbs on right metal retention arm, with the thumbs meeting in the center of the fully extended metal arm. Bend outwards and hold for 10 seconds.
131. Place thumbs on left metal retention arm, with one thumb on the plastic gimbal and the other thumb positioned in such a way that the center ie the bend point will be about 5mm above the gimbal. Bend outward and hold for 10seconds.
132. Place thumbs on right metal retention arm, with one thumb on the plastic gimbal and the other thumb positioned in such a way that the center ie the bend point will be about 5mm above the gimbal. Bend outward and hold for 10seconds.
133. Place thumbs on left metal retention arm, with the thumbs meeting in the center of the fully extended metal arm. Bend outwards and hold for 10 seconds.
134. Place thumbs on right metal retention arm, with the thumbs meeting in the center of the fully extended metal arm. Bend outwards and hold for 10 seconds.
135. Place thumbs on left metal retention arm, with one thumb on the plastic gimbal and the other thumb positioned in such a way that the center ie the bend point will be about 5mm above the gimbal. Bend outward and hold for 10seconds.
136. Place thumbs on right metal retention arm, with one thumb on the plastic gimbal and the other thumb positioned in such a way that the center ie the bend point will be about 5mm above the gimbal. Bend outward and hold for 10seconds.
137. Place thumbs on left metal retention arm, with the thumbs meeting in the center of the fully extended metal arm. Bend outwards and hold for 10 seconds.
138. Place thumbs on right metal retention arm, with the thumbs meeting in the center of the fully extended metal arm. Bend outwards and hold for 10 seconds.
139. Place thumbs on left metal retention arm, with one thumb on the plastic gimbal and the other thumb positioned in such a way that the center ie the bend point will be about 5mm above the gimbal. Bend outward and hold for 10seconds.
140. Place thumbs on right metal retention arm, with one thumb on the plastic gimbal and the other thumb positioned in such a way that the center ie the bend point will be about 5mm above the gimbal. Bend outward and hold for 10seconds.
141. Place thumbs on left metal retention arm, with the thumbs meeting in the center of the fully extended metal arm. Bend outwards and hold for 10 seconds.
142. Place thumbs on right metal retention arm, with the thumbs meeting in the center of the fully extended metal arm. Bend outwards and hold for 10 seconds.
143. Place thumbs on left metal retention arm, with one thumb on the plastic gimbal and the other thumb positioned in such a way that the center ie the bend point will be about 5mm above the gimbal. Bend outward and hold for 10seconds.
144. Place thumbs on right metal retention arm, with one thumb on the plastic gimbal and the other thumb positioned in such a way that the center ie the bend point will be about 5mm above the gimbal. Bend outward and hold for 10seconds.
145. Place thumbs on left metal retention arm, with the thumbs meeting in the center of the fully extended metal arm. Bend outwards and hold for 10 seconds.
146. Place thumbs on right metal retention arm, with the thumbs meeting in the center of the fully extended metal arm. Bend outwards and hold for 10 seconds.
147. Place thumbs on left metal retention arm, with one thumb on the plastic gimbal and the other thumb positioned in such a way that the center ie the bend point will be about 5mm above the gimbal. Bend outward and hold for 10seconds.
148. Place thumbs on right metal retention arm, with one thumb on the plastic gimbal and the other thumb positioned in such a way that the center ie the bend point will be about 5mm above the gimbal. Bend outward and hold for 10seconds.
149. Place thumbs on left metal retention arm, with the thumbs meeting in the center of the fully extended metal arm. Bend outwards and hold for 10 seconds.
150. Place thumbs on right metal retention arm, with the thumbs meeting in the center of the fully extended metal arm. Bend outwards and hold for 10 seconds.
151. Place thumbs on left metal retention arm, with one thumb on the plastic gimbal and the other thumb positioned in such a way that the center ie the bend point will be about 5mm above the gimbal. Bend outward and hold for 10seconds.
152. Place thumbs on right metal retention arm, with one thumb on the plastic gimbal and the other thumb positioned in such a way that the center ie the bend point will be about 5mm above the gimbal. Bend outward and hold for 10seconds.
153. Do a test fit. Is it good? No? Try adjusting how far out the metal arms are extended - shorter and longer. Did either work? If not, continue.
154. Place thumbs on left metal retention arm, with the thumbs meeting in the center of the fully extended metal arm. Bend outwards and hold for 10 seconds.
155. Place thumbs on right metal retention arm, with the thumbs meeting in the center of the fully extended metal arm. Bend outwards and hold for 10 seconds.
156. Place thumbs on left metal retention arm, with one thumb on the plastic gimbal and the other thumb positioned in such a way that the center ie the bend point will be about 5mm above the gimbal. Bend outward and hold for 10seconds.
157. Place thumbs on right metal retention arm, with one thumb on the plastic gimbal and the other thumb positioned in such a way that the center ie the bend point will be about 5mm above the gimbal. Bend outward and hold for 10seconds.
158. Place thumbs on left metal retention arm, with the thumbs meeting in the center of the fully extended metal arm. Bend outwards and hold for 10 seconds.
159. Place thumbs on right metal retention arm, with the thumbs meeting in the center of the fully extended metal arm. Bend outwards and hold for 10 seconds.
160. Place thumbs on left metal retention arm, with one thumb on the plastic gimbal and the other thumb positioned in such a way that the center ie the bend point will be about 5mm above the gimbal. Bend outward and hold for 10seconds.
161. Place thumbs on right metal retention arm, with one thumb on the plastic gimbal and the other thumb positioned in such a way that the center ie the bend point will be about 5mm above the gimbal. Bend outward and hold for 10seconds.
162. Place thumbs on left metal retention arm, with the thumbs meeting in the center of the fully extended metal arm. Bend outwards and hold for 10 seconds.
163. Place thumbs on right metal retention arm, with the thumbs meeting in the center of the fully extended metal arm. Bend outwards and hold for 10 seconds.
164. Place thumbs on left metal retention arm, with one thumb on the plastic gimbal and the other thumb positioned in such a way that the center ie the bend point will be about 5mm above the gimbal. Bend outward and hold for 10seconds.
165. Place thumbs on right metal retention arm, with one thumb on the plastic gimbal and the other thumb positioned in such a way that the center ie the bend point will be about 5mm above the gimbal. Bend outward and hold for 10seconds.
166. Place thumbs on left metal retention arm, with the thumbs meeting in the center of the fully extended metal arm. Bend outwards and hold for 10 seconds.
167. Place thumbs on right metal retention arm, with the thumbs meeting in the center of the fully extended metal arm. Bend outwards and hold for 10 seconds.
168. Place thumbs on left metal retention arm, with one thumb on the plastic gimbal and the other thumb positioned in such a way that the center ie the bend point will be about 5mm above the gimbal. Bend outward and hold for 10seconds.
169. Place thumbs on right metal retention arm, with one thumb on the plastic gimbal and the other thumb positioned in such a way that the center ie the bend point will be about 5mm above the gimbal. Bend outward and hold for 10seconds.
170. Place thumbs on left metal retention arm, with the thumbs meeting in the center of the fully extended metal arm. Bend outwards and hold for 10 seconds.
171. Place thumbs on right metal retention arm, with the thumbs meeting in the center of the fully extended metal arm. Bend outwards and hold for 10 seconds.
172. Place thumbs on left metal retention arm, with one thumb on the plastic gimbal and the other thumb positioned in such a way that the center ie the bend point will be about 5mm above the gimbal. Bend outward and hold for 10seconds.
173. Place thumbs on right metal retention arm, with one thumb on the plastic gimbal and the other thumb positioned in such a way that the center ie the bend point will be about 5mm above the gimbal. Bend outward and hold for 10seconds.
174. Place thumbs on left metal retention arm, with the thumbs meeting in the center of the fully extended metal arm. Bend outwards and hold for 10 seconds.
175. Place thumbs on right metal retention arm, with the thumbs meeting in the center of the fully extended metal arm. Bend outwards and hold for 10 seconds.
176. Place thumbs on left metal retention arm, with one thumb on the plastic gimbal and the other thumb positioned in such a way that the center ie the bend point will be about 5mm above the gimbal. Bend outward and hold for 10seconds.
177. Place thumbs on right metal retention arm, with one thumb on the plastic gimbal and the other thumb positioned in such a way that the center ie the bend point will be about 5mm above the gimbal. Bend outward and hold for 10seconds.
178. Place thumbs on left metal retention arm, with the thumbs meeting in the center of the fully extended metal arm. Bend outwards and hold for 10 seconds.
179. Place thumbs on right metal retention arm, with the thumbs meeting in the center of the fully extended metal arm. Bend outwards and hold for 10 seconds.
180. Place thumbs on left metal retention arm, with one thumb on the plastic gimbal and the other thumb positioned in such a way that the center ie the bend point will be about 5mm above the gimbal. Bend outward and hold for 10seconds.
181. Place thumbs on right metal retention arm, with one thumb on the plastic gimbal and the other thumb positioned in such a way that the center ie the bend point will be about 5mm above the gimbal. Bend outward and hold for 10seconds.
182. Place thumbs on left metal retention arm, with the thumbs meeting in the center of the fully extended metal arm. Bend outwards and hold for 10 seconds.
183. Place thumbs on right metal retention arm, with the thumbs meeting in the center of the fully extended metal arm. Bend outwards and hold for 10 seconds.
184. Place thumbs on left metal retention arm, with one thumb on the plastic gimbal and the other thumb positioned in such a way that the center ie the bend point will be about 5mm above the gimbal. Bend outward and hold for 10seconds.
185. Place thumbs on right metal retention arm, with one thumb on the plastic gimbal and the other thumb positioned in such a way that the center ie the bend point will be about 5mm above the gimbal. Bend outward and hold for 10seconds.
186. Place thumbs on left metal retention arm, with the thumbs meeting in the center of the fully extended metal arm. Bend outwards and hold for 10 seconds.
187. Place thumbs on right metal retention arm, with the thumbs meeting in the center of the fully extended metal arm. Bend outwards and hold for 10 seconds.
188. Place thumbs on left metal retention arm, with one thumb on the plastic gimbal and the other thumb positioned in such a way that the center ie the bend point will be about 5mm above the gimbal. Bend outward and hold for 10seconds.
189. Place thumbs on right metal retention arm, with one thumb on the plastic gimbal and the other thumb positioned in such a way that the center ie the bend point will be about 5mm above the gimbal. Bend outward and hold for 10seconds.
190. Place thumbs on left metal retention arm, with the thumbs meeting in the center of the fully extended metal arm. Bend outwards and hold for 10 seconds.
191. Place thumbs on right metal retention arm, with the thumbs meeting in the center of the fully extended metal arm. Bend outwards and hold for 10 seconds.
192. Place thumbs on left metal retention arm, with one thumb on the plastic gimbal and the other thumb positioned in such a way that the center ie the bend point will be about 5mm above the gimbal. Bend outward and hold for 10seconds.
193. Place thumbs on right metal retention arm, with one thumb on the plastic gimbal and the other thumb positioned in such a way that the center ie the bend point will be about 5mm above the gimbal. Bend outward and hold for 10seconds.
194. Place thumbs on left metal retention arm, with the thumbs meeting in the center of the fully extended metal arm. Bend outwards and hold for 10 seconds.
195. Place thumbs on right metal retention arm, with the thumbs meeting in the center of the fully extended metal arm. Bend outwards and hold for 10 seconds.
196. Place thumbs on left metal retention arm, with one thumb on the plastic gimbal and the other thumb positioned in such a way that the center ie the bend point will be about 5mm above the gimbal. Bend outward and hold for 10seconds.
197. Place thumbs on right metal retention arm, with one thumb on the plastic gimbal and the other thumb positioned in such a way that the center ie the bend point will be about 5mm above the gimbal. Bend outward and hold for 10seconds.
198. Place thumbs on left metal retention arm, with the thumbs meeting in the center of the fully extended metal arm. Bend outwards and hold for 10 seconds.
199. Place thumbs on right metal retention arm, with the thumbs meeting in the center of the fully extended metal arm. Bend outwards and hold for 10 seconds.
200. Place thumbs on left metal retention arm, with one thumb on the plastic gimbal and the other thumb positioned in such a way that the center ie the bend point will be about 5mm above the gimbal. Bend outward and hold for 10seconds.
201. Place thumbs on right metal retention arm, with one thumb on the plastic gimbal and the other thumb positioned in such a way that the center ie the bend point will be about 5mm above the gimbal. Bend outward and hold for 10seconds.
202. Do a test fit again. Did it work? Try everything again but this time when you bend it,
bend it more than you did previously.
Any ideas on the comfort of those 4? I know a lot of comfort is subjective depending on head size/ear size/etc but general idea will do. Not at my pc currently in middle of the night here so will research comfort aspect tomorrow..
AKG most comfortable to me but if you have large earlobes you'll wear them too centered to get the area that has the widest diameter, which may make them sound brighter. K701/702 earpads are angled to position the driver forward and at an angle relative to ear canal.
If you don't use them dead center, as with any large round earpad, you'll have more of the earbad in contect with the skin on your cheeks farther out from your ears and towards your nose. If your skin is easily irritated or you sweat on the pads and don't dry them much less wash them regularly, say hello to visible acne or worse.
Self adjusting headbands means the head size or afro haircut is critical. Too large? Good luck not having it clamp. Too small? They'll feel like nothing on your head and chances are they will fall off with the slightest movement.
