seanwee
- Jun 9, 2015
Who will be the king of the midrange
Stay updated on Cayin at their sponsor profile on Head-Fi.
Hot damn that's exactly what I asked for. Thanks Cayin!Announcement of Cayin N3Pro Firmware v2.1
New Functions and System Optimization
1. Rectified the system freezing problem when navigating through complex folder hierarchy.
Yup, no more issues@Philip Ha we have rectified the OGG problem you raised, please verify if this works fine with your OGG files.
@hemtmaker @powergeek @seanwee since you have reported system freeze up when browsing through folder hierarchy with 5 levels or more (well, seanwee never explain his problem clearly so I can only assume his problem is related to folder level based on his complain), can you please verify whether the new firmware have solved y our problem?
It so nice seeing a company continue supporting their product. Well done!@Philip Ha we have rectified the OGG problem you raised, please verify if this works fine with your OGG files.
The folder level problem were first reported by hemtmaker on 11 September, we need to enhance our file management coding at lower level programming before we can resolve the problem (hopefully). It is not exactly a bug but system optimisation, so it take a lot longer and we have to test it thoroughly, making sure it won't affect other existing function because low level file management were involved in many routines and features.
Hi, i updated while charging. It says in the website
“If the N3Pro is in charging status, the player will not reboot to main menu after firmware upgrade. It will stop at the battery charging page, you need to disconnect the USB charger to complete the firmware upgrade process.”
how do i proceed with the firmware upgrade? When i try to download ota its says “download failed”
Now I noticed it happened right after I was carrying it around. Stable it seems fine now. I think I've just been handling it too rough. I'm not used to tubes. or maybe the firmware upgrade helped, just upgraded it.
Andykong do you know how to batch resize album art ? , i know how to do it with MP3Tag, but only can get it one album at time.
I try BLISS https://www.blisshq.com/buy-fixes.html but us$79 is too much for me. (although it works perfectly)
