PinkyPowers
Reviewer: The Headphone List
Hello Head-Fi!
@Andykong of Cayin asked your dear old Pinky if I'd like to be a beta tester for their new music player, the N5ii. Naturally, I said yes. I love Cayin products... a lot. So, when I get my hands on the unit, I will share some of that experience with you, here in this thread.
This is also the best place for your general conversations about the N5ii. Impressions and reviews ought to be found here as well... when it hits the market.
In the meanwhile, enjoy some sweet, sweet info:
The Cayin N5 2nd Gen
MSRP: $369.99
Product Highlight
MCU: Rockchip RK3188
Display: 3.65” 845×480 TFT touch screen
DAC: ESS9018K2M
Op-Amp: OPA1622 x 3
Storage: 32GB + TF (up to 400GBx2)
Headphone: 3.5mm + 2.5mm (Balanced)
Line: 3.5mm (shared)
Digital: Coaxial, USB Audio (in/out)
USB: Type C (2.0), charging, OTG
System: Custom Android 5.1
RAM: 1G DDR3
Wi-Fi: 802.11 b/g/n 2.4GHz
Bluetooth: BT4.0 (SBC)
Battery: 3000mAH
Duration: ~12 hours (single-ended) ~9 hours (balanced)
Charging: ~3 hours (2.1A)
Dimension: 115*57*15.3 (mm)
Weight: ~150g
Specification
Phones Out (Single-ended)
Power rating: 150mW+150mW (@32Ω)
Frequency Response: 20-20kHz (±0.2dB, Fs=192kHz) 5-50kHz (±1dB, Fs=192kHz)
THD+N: 0.002% (1kHz, Fs=44.1kHz;20Hz-20kHz, A-Weighted)
Dynamic Range: 116dB (20Hz-20kHz, A-Weighted)
SNR: 116dB (20Hz-20kHz, A-Weighted)
Channel Separation: 76dB
Output Impedance: ≤0.4Ω
Connector: 3.5mm TRS (shared with Line Out)
Phones Out (Balanced)
Power rating: 250mW+250mW (@32Ω)
Dynamic Range: 117dB (20Hz-20kHz, A-Weighted)
SNR: 117dB (20Hz-20kHz, A-Weighted)
Channel Separation: 92dB
Output Impedance: ≤0.6Ω
Connector: 2.5mm TRRS
Line Out
Output Level: 2.0V (@10kΩ)
THD+N: 0.003% (1kHz, Fs=44.1kHz;20Hz-20kHz, A-Weighted)
Imp. matching: ≥10kΩ (suggested)
Connector 3.5mm TRS (shared with Phone Out)
USB Audio Output
DSD Mode: DSD64/DSD128, DoP or D2P*
PCM Mode: Upto 24Bit/384kHz
S/PDIF Output
DSD Mode: DSD64, DoP or D2P*
PCM Mode: Upto 24Bit/192kHz convert higher resolution to 176.4kHz or 192kHz
Recommended Headphone: impedance Range 16~200Ω (recommended)
*D2P: DSD to PCM, always output at 24bit/88.2kHz
MSRP: $369.99
Product Highlight
DAC: ESS9018K2M
Op-Amp: OPA1622 x 3
RAM: 1G DDR3
Battery: 3000mAH
Weight: ~150g
Specification
Line Out
USB Audio Output
S/PDIF Output
