amahikas
Sorry, the Qualcomm apt-xHD chip is way outside our budget on N5ii.
Thanks for Your reply!
I can feel the N5ii coming closer to me. Maybe not in distance, yet, but in time. I look forward to it, oh so much!
Stay updated on Cayin at their sponsor profile on Head-Fi.
Indeed they are.
We have the DAP beta units ready on 17th, unfortunately the package material was rejected by QA and we are waiting for the new batch of package material right now, it should arrive on Monday morning, we'll ship out the Beta units on Monday afternoon if things goes smoothly.
After so long a development, and so many delays and tragedies, I imagine you are insanely eager to see the end of this race, and release Cayin's newest masterpiece. And yet, not until every detail meets your standards. Must require great patience.
I wish the world is as beautiful as you have suggested.
Yes, we are struggling to get it out, but the struggling will far from complete when we send out the beta unit, maybe we can all it the beginning of the end,
According to the specs, just the one. Otherwise it would have an "X2" next to it. The OpAmps indicate 3, the microSD shows 2. But no such marking next to the DAC.
That is impossible to answer until Pinky receives his unit. It's in transit anyhow.Thank You! I'm in the process of looking at DAPS. I am definitely considering the Cayin I5 or Cayin N5 but I think I may be willing to wait until early December for this new offering. Would you by chance happen to know how much of an impact there is to sound using balanced output when comparing 1 dac to 2x dac systems? Maybe this is impossible to answer well.. Excuse me if that is the case. I know the amp portion is extremely important as well here.
For the record, 1xESS9018k2m is more expensive then 2xAK4490, we could have take the advantage of the marketing norm, save some money from production and gain more sales.
Aune M1S is perfect proof of this, it only uses one ESS 9018K2M. Now other audiophiles will disagree. But we've had tons of devices that only use one DAC and sound phenominal. If a designer concentrates all their ability and skill into a small focus, it would be well designed.I can confirm that the N5ii use one piece of ESS9018k2m DAC chipset.
I'll thrown in some general opinion but please be reminded that I work for Cayin, so you must take the conflict of interest factor into consideration.
If you are comparing 2x9018k2m vs 1x9018k2m, or 2xAK4490 vs 1xAK4490, and assume the DAC is implemented correctly, then I can tell you that it does matters, but not as significant as the marketing campaign has implied. Because N5ii is balanced amplified already, so you have more current, better control, separation, darker background and overhead already, so the dual chip option will grant you improve dynamic, SN ratio and channel seperation. One issue that I want to clarify is that you won't have more detail or higher resolution because of dual chip configuration, you might have heard more detail but I believe that's because of other improvements I have listed above that contribute to the "more detail" impression.
However, if you were to compare 1xESS9018k2m vs 2xAK4490, then the difference of DAC characteristics probably will be overwhelmed then the single vs dual chip scenario. ESS9018k2m is famous for its high resolution and it dies offered better specification (dynamic range, SN ratio, channel seperation) over AK4490. The common problem is 9018K2M sound cold and edging, but whether Cayin can take that characteristics? I think we better wait for the impression of the beta testers, I seldom comment on the subjective part of my products.
