I use my T2 with a bluetooth cable, so the stock cable is still white as snow inside the case with silica packs
CHIFI LOVE Thread-A never ending IEM-Heaphones-DAP-Dongles Sound Value Quest
- Thread starter NymPHONOmaniac
quiet different in sound presentation. T2 Has a more airy sound, lighter mids, colder treble, emphasis on deep sub bass but thin mid bass. King Pro has a warmer treble, thicker mids, more midbass slam. Both have great separation and staging. King pro has a more "inside a car" kind of presentation, while the T2 (because of their lesser isolation and airy nature) sounded more like the music floats around you
pedrothelion
What's the best chinese IEM's that I can get for classical music listening?
I want a neutral almost analytical sound, good instruments separation and wide soundtsage.
I'm waiting for a TENNMAK 'Crazy Cello' and in meanwhile I'm happy with the german clone of LIAM&DANN 'Swan'.
Thank you!
Thank you!
HUGO SILVA
- May 14, 2017
Hello friends, what would be the best in ear up to $ 60 that has a more balanced and neutral signature possible? I thought of Fiio F5 and TIN Audio T2. Is it worth paying more for the Fiio F5 or is there something better?
LordZero
- Oct 5, 2007
Interested in this! I don't know if the Tinaudio t2 is the more neutral iem available at that budget, but I love their sound.
HUGO SILVA
- May 14, 2017
is there any better than the neutral / balanced signature T2 up to $ 60 or $ 70?I prefer TinAudio T2 over Fiio F5
lordaine
Thank you!
https://spectrum.ieee.org/geek-life/reviews/earphone-showdown-part-2
Perception
Just a quick question, in the same vein as the best value for money Chinese IEMs, what are considered to be the best over ear Chinese headphones for sound quality around the $25 mark?
Cheers
Cheers
Superlux HD668B ?Just a quick question, in the same vein as the best value for money Chinese IEMs, what are considered to be the best over ear Chinese headphones for sound quality around the $25 mark?
Cheers
Superlux HD668B ?
I'll second that recommendation. At the $25 mark the Superlux 668 or 681 would be hard to beat.
guys I received the zhiyin z5000 and I can say only one thing ... this things are GREAT!!! this iem destroys all my other iems I like the bass subbass and the mids of this things this was the sound signature I was searching for a long time ... it has excellent imaging and resolution. it can drive very easy from smartphone... I cant thank enough... I wanna thank dhruvmeena96 darkzenith and hungrypanda for this little gem.. and ofcourse Nymphonomaniac because he found this little gem.. I am getting soon bgvp ds1 and the Yersen FEN-2000 I will leave some expressions too.... peace
Santojob
- Oct 12, 2010
I also really like the sound profile of the Z5000, I look forward to your impressions @zazaboy of the Bgvp Ds1 and the Yersen FEN-2000.guys I received the zhiyin z5000 and I can say only one thing ... this things are GREAT!!! this iem destroys all my other iems I like the bass subbass and the mids of this things this was the sound signature I was searching for a long time ... it has excellent imaging and resolution. it can drive very easy from smartphone... I cant thank enough... I wanna thank dhruvmeena96 darkzenith and hungrypanda for this little gem.. and ofcourse Nymphonomaniac because he found this little gem.. I am getting soon bgvp ds1 and the Yersen FEN-2000 I will leave some expressions too.... peace
A simple question is there any IEM with the sound profile similar to the Z5000? ..... the closest thing I have is the I-INTO i8.
The Tiandirenhe TD08 is probably my closest to zhiyin Z5000
