groucho69
with cayin n3 you've access to hiby music but no tidal/spotify option
I don't use those services but I'm pretty sure you can use them with the N3
Thank you ! Does any member know of any DAP/DAC brand where Bluetooth and Tidal/Spotify are available ?
I am looking for such an item to replace my Iphone Smartphone as source - would have to be superior in sound.
Much appreciate your recommendations. Thanks and regards !
If you are looking for a smartphone replacement as well then look into LG V30 (or V20 as a cheaper option). If your budget can accomodate it take the V30 flagship which has better battery life and people say it's more polished and what V20 should have been in the first place.
Both have audiophile grade Sabre quad DAC and hifi amp. Streaming services at best and naturally fluid interface common to smartphones, best compatibility with Playstore apps, Bluetooth, smartcard and so on.
There's a dedicated thread for it, check it out. Some people say is that good that they are ditching their mid tier daps for it.
Hi all,
Appreciate this is topic about IEMs but I only trust you and noone else so I post my question here. I have a big collection of IEMs (all your typical ones - couple TIN Audios, MEMT x5, Swing IE800, a bunch from KZ etc etc) and I have been using them with Cowon M2 as a DAP.
I am now looking for a new DAP and I am not even sure that it exists given my requirements:
Mandatory:
- Plays 24/96 FLAC
- Decent battery life (30 hours+... hard to accept anything worse after 90hrs Cowon M2)
- $150 max
- Doesn't require amp for sub-$50 chi-fi IEMs
Optional:
- Small
- Hardware buttons for volume, play/pause, previous/next
I hope you can recommend something!
Thanks, I count on your advice!
This is what i'm looking for. A more Fun signature.
See this comparision of @audio123 of ibasso and tfz king. They seem more like a sidegrade. So, maybe a exclusive 3 being a better cost benefit than exclusive king. It could be a good option for 49 dolars less than ibasso. Without compromising too much. Maybe...
If you could save up a bit, the King Pro is quite an upgrade to the regular King and more similar to the T2 than the regular (the regular King is Warmer while the Pro is more resolving) . Technically speaking, it's a more polished presentation than the T2, although i still think the T2 quite unique sounding.
King pro is too pricey and i want a bassier, more fun sound than T2. Not more resolving
I have the TFZ King
Thank you for the recommendation. Much obliged. Any other, specifically dedicated to music - not a smartphone as well ?
I have the Yersen FEN-2000 and my Rose North Forest is on the way! Thanks to all those who provided their thoughts. I would be happy to provide a comparison, however the right earpiece of my Yersens just failed . I requested a replacement from the AliExpress seller but I'm not holding my breath. It seems like there have been multiple people on this thread alone with the same problem. Until the QC issues are fixed, it's difficult for me to endorse the Yersen FEN-2000 (mine only lasted about a month with very careful use). A shame, since the sound quality and everything that comes in the package makes the price well worth it. I guess they had to cut corners somewhere and unfortunately it came at the expense of durability.
