Humblepie
eSmooth is based in China and makes wood cup headphones for other companies. They make headphones to spec for Symphonized, Meze, Griffin, and I learned not too long ago on these forums, DD Audio. The DXB-04 is available $99 shipped in the US, and might qualify as a 'gem':
http://ddaudio.com/products/lifestyle-and-gear/lifestyle/dxb-04-ear-wood-headphones
I don't have them, but there's an appreciation thread here which brought my attention to them:
https://www.head-fi.org/threads/dd-audio-dxb-04-appreciation-thread.859420/
eSmooth also makes some headphones under their own name, but they tend to be sold by other companies in a way that doesn't call out that they're eSmooth headphones (though in product photos you can usually still see the eSmooth name/logo on the headphones). For instance you can get the eSmooth ES-661 in walnut and rosewood through a seller on Amazon:
https://www.amazon.com/dp/B06XFPZ4MY/
https://www.amazon.com/dp/B06XFNP9R6/
The Griffin Woodtones are the same basic eSmooth design, but I think the Woodtones use plastic where the ES-661 use metal in the headband, and one of the reported issues from Amazon customers with the Woodtones is the headband snapping, so maybe the ES-661 is immune that problem? I also wonder if the drivers are the same. Maybe someone has more info.
Seen all those in the past. Problem is I am leery about buying unknown chi-fi at $100. Even $75 is pushing it for me. $50 or under and I'd buy them at some point for sure. $25 ish and I'd buy them now. Just at the $100 there are more known/reputable brands I don't own but can find a ton of support/reviews for in order to help prevent me from buying a turd. I have a few turds now, and luckily they've all been relatively cheap.
