mikp
- Jul 17, 2011
is the small cable straight one or coiled?
i want to ask him similar stuff.
always the coiled cables bring along higher impedance and this changes the sound. I would prefer to have to have both of them.
you can also user and aftermarket cable.
also i want an input on the sound considering the different plugs.
does the sound alter if you use the 6.3 plug instead of the 3.5 plug?
http://www.head-fi.org/t/510755/is-the-sound-quality-of-6-3-mm-better-than-using-the-headphone-with-a-3-5-mm-adapter#post_6903656
ok the plug does not make any difference in sound at all
any news on this?
The yenona seller shipped me the adapter cable a week later since the 3.5mm connection was loose. Good seller. For 37$ with extra pads as you mentioned Is good. The headphones has a big soundstage and are fun, just be realistic about the build quality.
